HP Officejet PRO AIO Wireless 6970 Inket 30 ppm
£114.55
22 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Easily print from a variety of smartphones and tablets.
  • Manage your budget with professional-quality colour at up to 50% less cost per page than lasers.
  • Save up to 70% on ink and never run out ink. Original HP ink. Ordered by your printer, delivered to your door.
  • Set the pace for success with rapid print, scan, and copy speeds.
  • Type: Fax / copier / printer / scanner
  • Functionality: Copier, Fax, Printer, Scanner
  • Max Paper Size: A4 (210 x 297 mm), Legal (216 x 356 mm)
  • Stock Status: In Stock
Product codes
Supercharge the office with affordable color and fast two-sided performance. Save paper with automatic two-sided printing, and handle more tasks without slowing down. Get a variety of mobile printing options and seamless mobile setup.
Product Description HP Officejet Pro 6970 All-in-One - multifunction printer - colour
Device Type Multifunction printer
Fax Type Plain paper
Localisation Western Europe, United Kingdom, Ireland, Nordics, Baltic Region
Printing Technology Ink-jet (colour)
Inkjet Technology HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max) 20000 pages
Recommended Monthly Volume 200 - 800 pages
Max Copying Speed Up to 30 ppm (mono) / up to 24 ppm (colour)
Max Copying Resolution Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed Up to 30 ppm (mono) / up to 26 ppm (colour)
Max Printing Resolution Up to 600 x 1200 dpi (mono) / up to 600 x 1200 dpi (colour)
Max Fax Transmission Speed 33.6 Kbps
Fax Resolutions 203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 200 x 200 dpi
Scanning 1200 dpi
Display 2.65"
Original Size Legal (216 x 356 mm)/A4 (210 x 297 mm) (max)
Original Type Sheets
Document Feeder Capacity 35 sheets
Media Size 88.9 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type Envelopes, plain paper, recycled paper, photo paper, thick paper, light-weight paper, glossy paper, matte paper
Standard Media Capacity 225 sheets
Output Trays Capacity 60 sheets
Automatic Duplexing Yes (copying) Yes (printing) Yes (scanning)
Connection Availability Yes
Interface USB 2.0, LAN, Wi-Fi(n), USB host
AirPrint Enabled Yes
Office Machine Features Print from USB flash drive, scan to folder
Power AC 120/230 V (50/60Hz)
Dimensions (WxDxH) 46.37 cm x 39 cm x 22.867 cm
Weight 8.1 kg
Environmental Standards ENERGY STAR Qualified
Manufacturer Warranty 3-year warranty with product registration
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP Officejet PRO AIO W...
£114.55
