HP P174 17" 1280x1024 5ms VGA LED Monitor
£132.08
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Attach your HP PC or select HP Thin Client directly behind the display.
  • Connect to your current and legacy devices through the VGA port.
  • Navigate your everyday content and specific line of business software on a sleek display that complements your modern workspace and has a standard 17-inch diagonal 1280 x 1024 resolution screen.
  • Diagonal Size: 17in
  • Max Resolution: 1280 x 1024
  • Response Time: 5ms
  • Speakers: None
  • Interfaces: VGA (HD-15)
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £135.57
Save £1.50
Meet your business needs and your budget with solid front-of-screen visuals and easy PC connectivity of the stylish, reliable, and affordable HP P174 17-inch Monitor.
Product Description HP P174 - LED monitor - 17"
Device Type LED-backlit LCD monitor - 17"
Aspect Ratio 5:4
Native Resolution 1280 x 1024 at 60 Hz
Pixel Pitch 0.264 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 10000000:1 (dynamic)
Response Time 5 ms (On/Off)
Colour Support 16.7 million colours
Input Connectors VGA
Display Position Adjustments Tilt
Screen Coating Anti-glare
Colour Black
Dimensions (WxDxH) - with stand 37.48 cm x 19 cm x 38.59 cm
Weight 2.6 kg
Localisation English / United Kingdom
Pricing Type Promo
Environmental Standards TCO Certified Displays 8, ENERGY STAR Qualified
Compliant Standards TUV GS, VCCI, BSMI, CB, CCC, FCC, KCC, Green Mark, ICES, S Mark, cTUVus, MEPS, E-Standby, CEC, KC, CECP, CEL, ISC, RCM, SEPA, BIS, CE/EMC, TUV LBL, IEC 62368
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP P174 17" 1280x1024...
£132.08
