We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Tackle your daily task list and save space on your desk with the compact, budget-friendly HP P19b G4 Monitor that adjusts to your comfort needs and delivers HD picture quality.
Product Description | HP P19b G4 - P-Series - LED monitor - 18.5" | Device Type | LED-backlit LCD monitor - 18.5" | Energy Class | Class C | Energy Consumption per Year | 12 kWh | Power Consumption (On mode) | 8.3 W | Panel Type | TN | Aspect Ratio | 16:9 | Native Resolution | WXGA 1366 x 768 at 60 Hz | Pixel Pitch | 0.3 mm | Brightness | 200 cd/m² | Contrast Ratio | 600:1 / 8000000:1 (dynamic) | Response Time | 5 ms | Colour Gamut | 72% NTSC | Input Connectors | HDMI, VGA | Display Position Adjustments | Tilt | Screen Coating | Anti-glare, Haze 25% | Voltage | AC 120/230 V (50/60 Hz) | Colour | Jack black | Dimensions (WxDxH) - with stand | 44.14 cm x 15.7 cm x 34.58 cm | Weight | 2.45 kg | Localisation | English / United Kingdom | Environmental Standards | TCO Certified Displays 8, ENERGY STAR Qualified EPEAT Silver | Compliant Standards | Plug and Play, TUV GS, VCCI, BSMI, NOM, TUV S, CB, CCC, PSB, KCC, WEEE, cTUVus, E-Standby, CEC, KC, CECP, CEL, EAC, ISC, SEPA, BIS, Mexico Energy label, Australian-New Zealand MEPS, Vietnam MEPS, South Africa Energy Label, TGM, Mexico LASE form | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 18.5" |
Panel Type | TN |
Vertical Refresh Rate | 50 - 60 Hz |
Horizontal Refresh Rate | 30 - 80 kHz |
Horizontal Viewing Angle | 90 |
Vertical Viewing Angle | 65 |
Backlight Technology | LED backlight |
Colour Temperature | 6500K |
OSD Languages | Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese |
Features | Low Blue Light Mode, Flicker Free technology, Mercury free, Color Calibrated, 72% NTSC colour gamut |
Dimensions (WxDxH) | 44.14 cm x 15.7 cm x 34.58 cm - with stand |
Weight | 2.45 kg |
Connectivity | |
Interfaces | HDMI (HDCP) , VGA |
Mechanical | |
Tilt Angle | -5/+22 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), VESA interface support |
Cables Included | 1 x VGA cable - 1.5 m |
Mounting Kit | Included |
Backlight Life | 30,000 hours |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 8.3 kWh/1000h |
Power Consumption (Typical) | 10 Watt |
Power Consumption Stand by | 0.5 Watt |
Software / System Requirements | |
Included Software | HP Display Assistant |
OS Required | Microsoft Windows 7 / 8 / 10 |
Dimensions & Weight | |
Dimensions & Weight Details | Without stand - width: 44.14 cm - depth: 5.07 cm - height: 27.78 cm - weight: 2.2 kg , With stand - width: 44.14 cm - depth: 15.7 cm - height: 34.58 cm - weight: 2.45 kg |
Dimensions & Weight (Shipping) | |
Shipping Weight | 3.27 kg |
Environmental Standards | |
TCO Certified | TCO Certified Displays 8 |
EPEAT Compliant | EPEAT Silver |
ENERGY STAR Certified | Yes |
ENERGY STAR Version | 8.0 |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 3 years - on-site |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 20 - 80% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
