HP P204 19.5" 1600x900 5ms VGA HDMI DisplayPort LED Monitor
£101.60
36 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Attach your HP PC or select HP Thin Client directly behind the display.
  • Easily navigate your documents and spreadsheets on this sleek display that complements your modern workspace and has a 19.5-inch diagonal screen with 1600 x 900 resolution.
  • Quickly connect to your devices and additional displays through the HDMI, DisplayPort™, and VGA connectors.
  • Diagonal Size: 19.5in
  • Max Resolution: 1600 x 900
  • Response Time: 5ms
  • Speakers: None
  • Interfaces: DisplayPort, HDMI, VGA (DB-15), VGA (HD-15)
Product codes
Get essential presentation features and device connectivity with the stylishly redesigned and surprisingly cost-conscious HP P204 19.5-inch Monitor.
Product Description HP P204 - LED monitor - 19.5"
Device Type LED-backlit LCD monitor - 19.5"
Energy Class Class A+
Energy Consumption per Year 18.9 kWh
Power Consumption (On mode) 13 W
Panel Type TN
Aspect Ratio 16:9
Native Resolution HD+ 1600 x 900 at 60 Hz
Pixel Pitch 0.27 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 10000000:1 (dynamic)
Response Time 5 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors HDMI, VGA, DisplayPort
Display Position Adjustments Tilt
Screen Coating Anti-glare
Colour Black
Dimensions (WxDxH) - with stand 46.26 cm x 19 cm x 35.36 cm
Weight 2.84 kg
Localisation English / United Kingdom
Environmental Standards ENERGY STAR Qualified
Compliant Standards Plug and Play, VCCI, BSMI, ISO 9001, GS, CB, CCC, PSB, FCC, KCC, WEEE, ICES, S Mark, cTUVus, MEPS, E-Standby, KC, ERP, CEL, EAC, ISC, RCM, MSIP, BIS, CoC, low halogen
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP P204 19.5" 1600x900...
£101.60
