HP P22 G4 21.5" 1920x1080 5ms VGA HDMI IPS LED Monitor
FREE DELIVERY
£120.00
More than 50 In Stock
Delivery:
Standard: 1-3 working days
Key features
  • Navigate documents and spreadsheets and work in applications side by side on the 21.5" (54.61 cm) diagonal Full HD IPS screen with 1920 x 1080 resolution.
  • Complement your workspace with a contemporary display that has a 3-sided micro-edge bezel for unlimited sightlines and virtually seamless multi-display setups.
  • Quickly connect to your devices and additional displays through the HDMI, DisplayPort , and VGA connectors.
  • Diagonal Size: 21.5in
  • Max Resolution: 1920 x 1080
  • Response Time: 5ms
  • Speakers: None
  • Interfaces: HDMI, VGA (HD-15), DisplayPort
Product codes
Put your content front and center on the HP P22 G4 FHD Monitor. The stylish, sleek design delivers essential presentation features, visual comfort, and advanced connectivity at a remarkable price point.
Product Description HP P22 G4 - P-Series - LED monitor - Full HD (1080p) - 21.5"
Device Type LED-backlit LCD monitor - 21.5"
Energy Class Class E
Energy Consumption per Year 19.3 kWh
Power Consumption (On mode) 14 W
Panel Type IPS
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Pixel Pitch 0.24795 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 8000000:1 (dynamic)
Response Time 5 ms (grey-to-grey with overdrive)
Input Connectors HDMI, VGA, DisplayPort
Display Position Adjustments Tilt
Screen Coating Anti-glare, 3H Hard Coating
Voltage AC 120/230 V (50/60 Hz)
Colour Black
Dimensions (WxDxH) - with stand 49.73 cm x 21.16 cm x 45.49 cm
Weight 4.14 kg
Localisation English / United Kingdom
Environmental Standards ENERGY STAR Qualified EPEAT Silver
Compliant Standards Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, ICES, KC, CEL, EAC, ISC, DisplayPort 1.2, Australian-New Zealand MEPS, Vietnam MEPS
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£120.00
