HP P224 21.5" 1920x1080 5ms VGA HDMI DisplayPort LED Mon...
HP P224 21.5" 1920x1080 5ms VGA HDMI DisplayPort LED Monitor
£118.52
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Complement your modern workspace with a display that has a contemporary look and feel and a 3-sided micro-edge bezel for unlimited sightlines and virtually seamless multi-display setups.
  • Easily navigate your documents and spreadsheets on the ample 21.5-inch diagonal Full HD screen with vibrant 1920 x 1080 resolution.
  • Quickly connect to your devices and additional displays through the HDMI, DisplayPort™, and VGA connectors.
  • Diagonal Size: 21.5in
  • Max Resolution: 1920 x 1080
  • Response Time: 5ms
  • Speakers: None
  • Interfaces: DisplayPort, HDMI, VGA (DB-15)
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £122.01
Save £1.50
Put more of your content front and center on the HP P224 21.5-inch Monitor. The stylishly modern and sleek profile design delivers essential presentation features and advanced connectivity at a remarkable price point.
Product Description HP P224 - LED monitor - Full HD (1080p) - 21.5"
Device Type LED-backlit LCD monitor - 21.5"
Energy Class Class A+
Energy Consumption per Year 20 kWh
Power Consumption (On mode) 17 W
Panel Type VA
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Pixel Pitch 0.248 mm
Brightness 250 cd/m²
Contrast Ratio 2000:1 / 10000000:1 (dynamic)
Response Time 5 ms (grey-to-grey)
Input Connectors HDMI, VGA, DisplayPort
Display Position Adjustments Tilt
Screen Coating Anti-glare
Colour Black
Dimensions (WxDxH) - with stand 48.85 cm x 18.1 cm x 37.1 cm
Weight 3 kg
Localisation English / United Kingdom
Environmental Standards ENERGY STAR Qualified
Compliant Standards Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, MEPS, KC, CECP, CEL, EAC, ISC, SEPA, low halogen, ICE
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP P224 21.5" 1920x108...
£118.52
