HP P244 23.8" 1920x1080 5ms VGA HDMI DisplayPort IPS LED...
HP P244 23.8" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor
£130.35
Delivery:
Standard: 1-3 working days
Key features
  • Easily navigate documents and spreadsheets and work in multiple applications side by side on the 23.8-inch diagonal Full HD screen with vibrant 1920 x 1080 resolution.
  • Quickly connect to your devices and additional displays through the HDMI, DisplayPort™, and VGA connectors.
  • Set a new style standard with a 3-sided micro-edge bezel for unlimited sightlines and virtually seamless multi-display setups. See the screen clearly from almost anywhere with 178° viewing angles.
  • Diagonal Size: 23.8in
  • Max Resolution: 1920 x 1080
  • Response Time: 5ms
  • Speakers: None
  • Interfaces: DisplayPort, HDMI, VGA (HD-15)
Product codes
See more of your work onscreen with minimal window toggling on the stylishly modern HP P244 23.8-inch Monitor. It complements your modern workspace with a sleek profile, IPS screen, and 3-sided micro-edge bezels while delivering business-class presentation features and advanced connectivity.
Product Description HP P244 - LED monitor - Full HD (1080p) - 23.8"
Device Type LED-backlit LCD monitor - 23.8"
Energy Class Class A
Energy Consumption per Year 25 kWh
Power Consumption (On mode) 17 W
Panel Type IPS
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Pixel Pitch 0.2745 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 10000000:1 (dynamic)
Response Time 5 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors HDMI, VGA, DisplayPort
Display Position Adjustments Tilt
Screen Coating Anti-glare
Colour Black
Dimensions (WxDxH) - with stand 53.91 cm x 20 cm x 39.75 cm
Weight 3.8 kg
Localisation English / United Kingdom
Environmental Standards ENERGY STAR Qualified
Compliant Standards Plug and Play, UL, VCCI, BSMI, GS, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, MEPS, KC, CECP, CEL, ISC, SEPA, BIS, low halogen
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP P244 23.8" 1920x108...
£130.35
