We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
See more of your work onscreen with less window toggling on the HP P24h G4 FHD Height Adjust Monitor. It has business-class presentation features, adjustable comfort, stereo audio, and advanced connectivity to complement today's workspaces.
Product Description | HP P24h G4 - LED monitor - Full HD (1080p) - 23.8" | Device Type | LED-backlit LCD monitor - 23.8" | Energy Class | Class E | Energy Consumption per Year | 20.8 kWh | Power Consumption (On mode) | 15 W | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Pixel Pitch | 0.2745 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 8000000:1 (dynamic) | Response Time | 5 ms (grey-to-grey) | Colour Gamut | 72% NTSC | Input Connectors | HDMI, VGA, DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Anti-glare | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 53.82 cm x 21.16 cm x 46.43 cm | Weight | 4.61 kg | Localisation | English / United Kingdom | Environmental Standards | ENERGY STAR Qualified EPEAT Silver | Compliant Standards | Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, MEPS, KC, CEL, EAC, ISC, low halogen, ICE |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 23.8" |
Panel Type | IPS |
Pixel Per Inch | 93 |
Vertical Refresh Rate | 48 - 75 Hz |
Horizontal Refresh Rate | 30 - 86 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Colour Temperature | 6500K |
OSD Languages | Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese |
Features | HDCP, On-screen Digital Controls, Low Blue Light Mode, Flicker Free technology, Mercury free, Factory Calibration, arsenic-free glass, 3-sided micro-edge, 72% NTSC colour gamut |
Colour | Black |
Dimensions (WxDxH) | 53.82 cm x 21.16 cm x 46.43 cm - with stand |
Weight | 4.61 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 2 Watt |
Connectivity | |
Interfaces | DisplayPort (HDCP) , HDMI (HDCP) , VGA , Audio line-in |
Mechanical | |
Tilt Angle | -5/+23 |
Swivel Angle | 360 |
Rotation Angle | 90 |
Height Adjustment | 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), detachable stand, VESA interface support |
Cables Included | 1 x VGA cable - 1.8 m , 1 x HDMI cable - 1.8 m , 1 x audio cable - 1.8 m |
Backlight Life | 30,000 hours |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 15 kWh/1000h |
Power Consumption (Typical) | 22 Watt |
Power Consumption Stand by | 0.5 Watt |
Software / System Requirements | |
Included Software | HP Display Assistant |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 53.82 cm - depth: 21.16 cm - height: 46.43 cm - weight: 4.61 kg , Without stand - width: 53.82 cm - depth: 4.59 cm - height: 32.56 cm - weight: 2.53 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 59.8 cm |
Shipping Depth | 16.5 cm |
Shipping Height | 41.5 cm |
Shipping Weight | 6.14 kg |
Environmental Standards | |
EPEAT Compliant | EPEAT Silver |
ENERGY STAR Certified | Yes |
ENERGY STAR Version | 8.0 |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 20 - 80% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
