We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Enjoy a stylish, height-adjustable display with sharp QHD resolution and ultra-wide viewing angles on the HP P24q 23.8" monitor. This ultra slim, 3-sided micro-edge display comes at a great value with convenient HDMI and VGA connectivity.
Product Description | HP P24q G4 - P-Series - LED monitor - 23.8" | Device Type | LED-backlit LCD monitor - 23.8" | Energy Class | Class G | Power Consumption (On mode) | 26 W | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | QHD 2560 x 1440 at 60 Hz | Pixel Pitch | 0.2058 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 10000000:1 (dynamic) | Response Time | 5 ms (grey-to-grey) | Colour Gamut | 99% sRGB | Input Connectors | HDMI, VGA | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Anti-glare, 3H Hard Coating | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 54.06 cm x 21.16 cm x 46.33 cm | Weight | 5.59 kg | Localisation | English / United Kingdom | Compliant Standards | Plug and Play, BSMI, NOM, WHQL, CB, CCC, FCC, ISO 9241-307, ICES, S Mark, cTUVus, TUV Bauart, China Energy Label Level 2, CEC, ERP, CECP, CEL, EAC, UAE, Ukraine Energy Label |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 23.8" |
Panel Type | IPS |
Pixel Per Inch | 123 |
Vertical Refresh Rate | 50 - 60 Hz |
Horizontal Refresh Rate | 30 - 80 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Colour Temperature | 6500K |
OSD Languages | Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese |
Features | High Frame Rate Control (Hi-FRC), Flicker Free technology, 3-sided micro-edge, 6-bit + FRC Color Depth |
Colour | Black |
Dimensions (WxDxH) | 54.06 cm x 21.16 cm x 46.33 cm - with stand |
Weight | 5.59 kg |
Connectivity | |
Interfaces | HDMI , VGA |
Mechanical | |
Tilt Angle | -5/+23 |
Swivel Angle | 360 |
Rotation Angle | 90 |
Height Adjustment | 100 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), detachable stand, VESA interface support, HDCP Compliant, arsenic free, mercury free |
Cables Included | 1 x HDMI cable - 1.8 m |
Backlight Life | 30,000 hours |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 26 kWh/1000h |
Power Consumption (Typical) | 26 Watt |
Power Consumption Stand by | 0.5 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 54.06 cm - depth: 21.16 cm - height: 46.33 cm - weight: 5.59 kg , Without stand - width: 54.06 cm - depth: 4.69 cm - height: 32.25 cm - weight: 3.42 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 63.9 cm |
Shipping Depth | 22.5 cm |
Shipping Height | 41.9 cm |
Shipping Weight | 7.59 kg |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 20 - 80% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
