We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Tackle your daily to-do list and multi-task across multiple windows on the extra-large 27" diagonal HP P27v G4 Monitor that adjusts to your comfort needs and delivers Full HD picture quality with clear 178° sightlines.
Product Description | HP P27v G4 - P-Series - LED monitor - Full HD (1080p) - 27" | Device Type | LED-backlit LCD monitor - 27" | Energy Class | Class E | Energy Consumption per Year | 32 kWh | Power Consumption (On mode) | 20.4 W | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Pixel Pitch | 0.3114 mm | Brightness | 300 cd/m² | Contrast Ratio | 1000:1 / 8000000:1 (dynamic) | Response Time | 5 ms (On/Off) | Colour Gamut | 72% NTSC | Input Connectors | HDMI, VGA | Display Position Adjustments | Tilt | Screen Coating | Haze 25%, anti-glare 3H hardness | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 61.22 cm x 20.01 cm x 44.77 cm | Weight | 4.5 kg | Localisation | English / United Kingdom | Environmental Standards | TCO Certified Displays 8, ENERGY STAR Qualified | Compliant Standards | VCCI, C-Tick, BSMI, CB, CCC, PSB, FCC, ISO 9241-307, KCC, Energy-using Products (EuP) Lot 6, WEEE, cTUVus, TUV Bauart, E-Standby, CEC, UkrSEPRO, KC, CECP, EAC, ISC, CEL Grade 2, SEPA, BIS, Energy-using Products (EuP) Lot 5, NOM-NYCE, ICE, Australian-New Zealand MEPS, Vietnam MEPS, Mexico MEPS, South Africa MEPS, Ukraine Energy Label, Japan PC Green Label | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 27" |
Panel Type | IPS |
Pixel Per Inch | 81.59 |
Vertical Refresh Rate | 50 - 60 Hz |
Horizontal Refresh Rate | 30 - 80 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
OSD Languages | Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese |
Features | Low Blue Light Mode, Color Calibrated, 3-sided micro-edge, 72% NTSC colour gamut |
Colour | Black |
Dimensions (WxDxH) | 61.22 cm x 20.01 cm x 44.77 cm - with stand |
Weight | 4.5 kg |
Connectivity | |
Interfaces | HDMI , VGA |
Mechanical | |
Tilt Angle | -5/+20 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), arsenic free, mercury free |
Cables Included | 1 x VGA cable - 1.5 m |
Backlight Life | 30,000 hours |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 20.4 kWh/1000h |
Power Consumption (Typical) | 28 Watt |
Power Consumption Stand by | 0.5 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 61.22 cm - depth: 20.01 cm - height: 44.77 cm - weight: 4.5 kg , Without stand - width: 61.22 cm - depth: 4.77 cm - height: 36.77 cm - weight: 4 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 67.5 cm |
Shipping Depth | 12.8 cm |
Shipping Height | 42.5 cm |
Shipping Weight | 5.7 kg |
Environmental Standards | |
TCO Certified | TCO Certified Displays 8 |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 3 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 20 - 80% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
