HP PageWide 755DN Colour 55ppm Printer
£2,136.68
Delivery:
Standard: 1-3 working days
Key features
  • A suite of embedded security features help protect this printer from being an entry point for attacks.
  • Conserve resources with HP PageWide – designed to use less energy than any laser printer in its class.
  • Get the quality you expect with HP PageWide Technology that delivers the lowest cost per colour page.
  • Minimise interruptions with an HP PageWide printer designed for the least maintenance in its class.
  • Type: Printer
  • Functionality: Printer
  • Output Type: Colour
  • Wireless Capability: Wired
  • Max Print Speed: 55ppm
Product codes
Business moves fast, and slowing down means falling behind. It's why HP built the next generation of HP PageWide – to power productivity with a smart, efficient design that delivers the lowest colour cost, maximum uptime, and strong security.
Dynamic security enabled printer. Only intended to be used with cartridges using an HP original chip. Cartridges using a non-HP chip may not work, and those that work today may not work in the future.
Product Description HP PageWide Color 755dn - printer - colour - page wide array
Printer Type Workgroup printer - page wide array - colour
Weight 22.15 kg
Localisation English, German, French, Italian, Spanish / Europe
Inkjet Technology HP PageWide
Ink Palette Supported (Colours) 4-ink - cyan, magenta, yellow, black
Media Size Class A3
Max Media Size A3 (297 x 420 mm)
Min Media Size (Custom) 76 mm x 127 mm
Max Media Size (Custom) 216 mm x 457.2 mm
Print Speed Up to 55 ppm - black draft - A4 (210 x 297 mm) , Up to 55 ppm - colour draft - A4 (210 x 297 mm) , Up to 35 ppm - B/W (ISO/IEC 24734) , Up to 35 ppm - color (ISO/IEC 24734) , Up to 35 ppm - black normal - A4 (210 x 297 mm) , Up to 35 ppm - colour normal - A4 (210 x 297 mm) , Up to 24 ipm - B/W duplex - A4 (210 x 297 mm) , Up to 24 ipm - colour duplex - A4 (210 x 297 mm)
Max Resolution (B&W) 1200 x 1200 dpi
Max Resolution (Colour) 2400 x 1200 dpi
Automatic Duplexing Yes
Interface USB 2.0, LAN, Wi-Fi(n), USB 2.0 host
Preview Screen Size 4.3"
Processor 1.2 GHz
Language Simulation PostScript 3, PCL 6, PCL XL, PDF
Media Type Envelopes, greeting cards, labels, plain paper, photo paper, cards, bond paper, recycled paper, brochure paper, tri-fold brochure paper, extra heavy-weight paper, light-weight paper, punched paper
Total Media Capacity 550 sheets
Media Handling 500-sheet input tray, 50-sheet multipurpose tray
Monthly Duty Cycle (max) 75000 pages
Recommended Monthly Volume 2500 - 15000 pages
Printer Features HP EasyColor
Power AC 120/230 V
System Requirements UNIX, Linux, Novell NetWare 6, Novell NetWare 6.5, Microsoft Windows Server 2003 Standard x64 Edition, Microsoft Windows Server 2003 Enterprise x64 Edition, Microsoft Windows Server 2003 R2 Enterprise x64 Edition, Microsoft Windows Server 2003 R2 Standard x64 Edition, Microsoft Windows Server 2008 R2, Apple MacOS X 10.6, Microsoft Windows Vista (32-bit versions), Microsoft Windows Compute Cluster Server, Citrix Presentation Server 4.5, Microsoft Windows Server 2008 Enterprise x64 Edition, Microsoft Windows Server 2008 Standard x64 Edition, Citrix Presentation Server 4.0, Microsoft Windows 7 (32/64 bits), Microsoft Windows Small Business Server 2008 x64 Edition, Microsoft Windows Small Business Server 2011, Citrix XenApp 6.0 64-bit, Citrix XenServer 5.6, Citrix XenDesktop 5.5, Microsoft Windows Server 2012, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), Citrix XenApp, Microsoft Windows Small Business Server 2003 (32/64 bits), Citrix XenApp 6.5, Microsoft Windows XP SP2 (32 bit) or later, Windows 8.1 (32/64 bits), Apple OS X 10.9 Mavericks, Microsoft Windows Server 2008 R2 Enterprise (64-bit), Microsoft Windows Server 2008 R2 Standard (64-bit), Microsoft Windows XP SP3 (32 bit) or later, Apple OS X 10.10 Yosemite, Microsoft Windows Server 2003 R2 Standard Edition (32-bit), Windows 10 (32/64 bits), Microsoft Windows Server 2003 Standard Edition (32-bit), Microsoft Windows Server 2003 Enterprise Edition (32-bit)
Manufacturer Warranty 1-year warranty
Dimensions (WxDxH) 60.4 cm x 65.2 cm x 46.7 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP PageWide 755DN Colo...
£2,136.68
