HP PageWide 780DN Colour 45ppm Multifunction Printer
£3,797.54
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Each printer in your fleet checks its operating code and repairs itself from attacks.
  • Get the quality you expect with HP PageWide Technology that delivers the lowest cost per colour page.
  • Minimise interruptions with an HP PageWide device designed for the least maintenance in its class.
  • Type: Fax / copier / printer / scanner
  • Functionality: Copier, Fax, Printer, Scanner
  • Output Type: Colour
  • Wireless Capability: Wireless
  • Max Print Speed: 45ppm
Product codes
Modern business demands forward-thinking technology – it's why HP engineered the next generation of HP PageWide Enterprise to deliver a competitive edge from every angle: lowest colour cost, maximum uptime and the industry's strongest security.
Dynamic security enabled printer. Only intended to be used with cartridges using an HP original chip. Cartridges using a non-HP chip may not work, and those that work today may not work in the future.
Product Description HP PageWide Enterprise Color MFP 780dn - multifunction printer - colour
Device Type Multifunction printer
Fax Type Plain paper
Localisation English, German, French, Italian, Spanish / Europe
Printing Technology Page wide array (colour)
Inkjet Technology HP PageWide - 4-ink
Monthly Duty Cycle (max) 100000 pages
Recommended Monthly Volume 2500 - 20000 pages
Max Copying Speed Up to 45 ppm (mono) / up to 45 ppm (colour)
Max Copying Resolution Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed Up to 65 ppm (mono) / up to 65 ppm (colour)
Max Printing Resolution Up to 1200 x 1200 dpi (mono) / up to 2400 x 1200 dpi (colour)
Max Fax Transmission Speed 33.6 Kbps
Fax Resolutions 300 x 300 dpi, 204 x 98 dpi, 204 x 196 dpi
Scanning 600 dpi
Display 8"
Original Size 100 x 148 mm (min) - 297 x 432 mm (max)
Original Type Sheets
Document Feeder Capacity 100 sheets
Media Size 100 x 148 mm (min) - 297 x 432 mm, RA3 (305 x 430 mm) (max)
Media Type Envelopes, plain paper, cards, labels, photo paper, glossy paper
Standard Media Capacity 650 sheets
Max Media Capacity 4650 sheets
Bypass Feeder Capacity 60 sheets
Output Trays Capacity 500 sheets
Automatic Duplexing Yes (copying) Yes (printing) Yes (scanning)
Connection Availability Yes
Interface USB 2.0, Gigabit LAN, USB 2.0 host
AirPrint Enabled Yes
Office Machine Features Save to USB flash drive, scan to e-mail, Hardware Integration Pocket, save to network folder, HP EasyColor, HP Auto-On/Auto-Off Technology, Open Extensibility Platform (OXP)
Power AC 120/230 V (50/60Hz)
Dimensions (WxDxH) 81.3 cm x 59.1 cm x 45.8 cm
Weight 68 kg
Environmental Standards ENERGY STAR Qualified
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP PageWide 780DN Colo...
£3,797.54
