Ultimate value for today's enterprise – HP PageWide Technology delivers the fastest speeds and deepest security for the lowest total cost of ownership in its class. Count on productivity and unparalleled multi-level security.
Dynamic security enabled printer. Only intended to be used with cartridges using an HP original chip. Cartridges using a non-HP chip may not work, and those that work today may not work in the future.
Product Description | HP PageWide Enterprise Color 556xh - printer - colour - page wide array | Printer Type | Workgroup printer - page wide array - colour | Weight | 28.8 kg | Localisation | English, German, French, Italian, Spanish / Europe | Ink Palette Supported (Colours) | 4-ink - cyan, magenta, yellow, black | Media Size Class | A4/Legal | Max Media Size | Legal (216 x 356 mm), A4 (210 x 297 mm) | Min Media Size (Custom) | 76 mm x 127 mm | Max Media Size (Custom) | 216 mm x 356 mm | Print Speed | Up to 75 ppm - black draft - A4 (210 x 297 mm) , Up to 50 ppm - B/W - A4 (210 x 297 mm) , Up to 75 ppm - colour draft - A4 (210 x 297 mm) , Up to 50 ppm - colour - A4 (210 x 297 mm) , Up to 38 ipm - B/W duplex - A4 (210 x 297 mm) , Up to 25 ppm - colour duplex - A4 (210 x 297 mm) | Max Resolution (B&W) | 1200 x 1200 dpi | Max Resolution (Colour) | 2400 x 1200 dpi | Automatic Duplexing | Yes | Interface | USB 2.0, Gigabit LAN, Wi-Fi(n), NFC, USB 2.0 host | AirPrint Enabled | Yes | Preview Screen Size | 4.3" | Processor | 1.2 GHz | RAM Installed (Max) | 1.25 GB (2.25 GB) | Hard Drive | 320 GB | Language Simulation | PCL 5, PostScript 3, PCL 6, PDF 1.4 | Media Type | Envelopes, greeting cards, labels, plain paper, glossy photo paper, heavy-weight paper, matt photo paper, bond paper, recycled paper, tri-fold brochure paper, extra heavy-weight paper, light-weight paper, soft gloss photo paper, punched paper, satin photo paper | Total Media Capacity | 1050 sheets | Media Handling | 2x 500-sheet input trays, 50-sheet multipurpose tray | Monthly Duty Cycle (max) | 80000 pages | Recommended Monthly Volume | 2000 - 7500 pages | Networking | Print server | Printer Features | Hard Disk Drive Encryption | Power | AC 120/230 V | System Requirements | UNIX, Android, Ubuntu 10.04, Microsoft Windows XP (32/64 bits) SP3, Apple iOS, Ubuntu 11.10, Ubuntu 12.04, Red Hat Fedora 17, Ubuntu 12.10, Apple MacOS X 10.9, Red Hat Fedora 18, Linux Mint 13, Microsoft Windows RT 8.1, Ubuntu 13.04, Ubuntu 13.10, Ubuntu 14.04, Red Hat Fedora 19, Microsoft Windows RT 8, Linux Mint 14, Linux Mint 15, Apple MacOS X 10.10, Red Hat Fedora 20, Linux Mint 16, Linux Mint 17, BOSS GNU/Linux 3.0, BOSS GNU/Linux 5.0, Ubuntu 14.10, Debian Linux 6.0.x, Debian Linux 7.x, Microsoft Vista / 7 / 8 / 8.1 / 10 (32/64 bits), Apple MacOS X 10.11, SUSE Linux 12.2, SUSE Linux 12.3, SUSE Linux 13.1, Windows 10 Mobile | Manufacturer Warranty | 1-year warranty | Dimensions (WxDxH) | 53 cm x 46.3 cm x 59.7 cm |
General | |
Printer | |
Ink Cartridge Configuration | 4 cartridges (1 each: cyan, magenta, yellow, black) |
Built-in Devices | Touch screen |
Connectivity Technology | Wireless |
First Print Out Time B/W | 7.1 sec |
First Print Out Time Colour | 7.3 sec |
Fonts Included | 105 x TrueType , 92 x PostScript 3 |
Processor | |
RAM | |
RAM Installed (Max) | 1.25 GB / 2.25 GB (max) |
Storage | |
Media Handling | |
Media Sizes | ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), 216 x 297 mm, 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 76 x 127 mm, 127 x 177.8 mm, Oficio (216 x 343 mm), 127 x 203.2 mm, 102 x 210 mm |
Envelope Sizes | US No 10 (104.7 x 241.3 mm), Monarch (98.4 x 190.5 mm) |
Media Feeders | 1 x automatic - 50 sheets - Legal (216 x 356 mm) , 2 x automatic - 500 sheets - Legal (216 x 356 mm) |
Output Trays Capacity | 300 sheets |
Duty Cycle | |
Networking | |
Remote Management Protocol | Telnet, SNMP 3, IPP, HTTP, HTTPS, TFTP, SLP |
Security Protocols & Features | SSL, Apple Bonjour, TLS, IPsec, 802.1x, AES-256, WPA2-Enterprise |
Expansion / Connectivity | |
Connections | 1 x USB 2.0 - 4 pin USB Type B , 2 x USB 2.0 host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45 |
Miscellaneous | |
Consumables Included | 1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow) |
Features | 256-bit AES hardware encryption |
Compliant Standards | UL, cUL, GS, Directive 2006/95/EC, EN 62479:2010, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62479:2010, EN 60950-1:2006 + A11:2009 + A1:2010 + A12:2011 + A2:2013 |
Power | |
Power Device | Power supply - internal |
Voltage Required | AC 120/230 V |
Frequency Required | 50/60 Hz |
Power Consumption Operational | 52 Watt |
Power Consumption Stand by | 12 Watt |
Power Consumption Sleep | 6.3 Watt |
Software / System Requirements | |
Software Included | Drivers & Utilities, HP Web JetAdmin, HP Software Update |
OS Required | UNIX, Android, Ubuntu 10.04, Microsoft Windows XP (32/64 bits) SP3, Apple iOS, Ubuntu 11.10, Ubuntu 12.04, Red Hat Fedora 17, Ubuntu 12.10, Apple MacOS X 10.9, Red Hat Fedora 18, Linux Mint 13, Microsoft Windows RT 8.1, Ubuntu 13.04, Ubuntu 13.10, Ubuntu 14.04, Red Hat Fedora 19, Microsoft Windows RT 8, Linux Mint 14, Linux Mint 15, Apple MacOS X 10.10, Red Hat Fedora 20, Linux Mint 16, Linux Mint 17, BOSS GNU/Linux 3.0, BOSS GNU/Linux 5.0, Ubuntu 14.10, Debian Linux 6.0.x, Debian Linux 7.x, Microsoft Vista / 7 / 8 / 8.1 / 10 (32/64 bits), Apple MacOS X 10.11, SUSE Linux 12.2, SUSE Linux 12.3, SUSE Linux 13.1, Windows 10 Mobile |
System Requirements Details | HD 200 MB , MacOS - HD 1 GB |
Environmental Standards | |
Blue Angel | Yes |
ENERGY STAR | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year - on-site - response time: next business day |
Environmental Parameters | |
Min Operating Temperature | 15 °C |
Max Operating Temperature | 30 °C |
Humidity Range Operating | 20 - 80% |
Sound Emission (Operating) | 55 dBA |
Dimensions & Weight | |
Width | 53 cm |
Depth | 46.3 cm |
Height | 59.7 cm |
Weight | 28.8 kg |
Dimensions & Weight (Shipping) | |
Width (Shipping) | 60.3 cm |
Depth (Shipping) | 56.5 cm |
Height (Shipping) | 79.2 cm |
Weight (Shipping) | 35.4 kg |
