General |
Device Type |
Multifunction printer |
Fax Type |
Plain paper |
Printing Technology |
Page wide array - colour |
Monthly Duty Cycle (max) |
80000 pages |
Recommended Monthly Volume |
2000 - 7500 pages |
Display Diagonal Size |
8" |
Display Features |
Touch screen |
Connection Availability |
Yes |
Interface |
USB 2.0, Gigabit LAN, USB 2.0 host, USB 2.0 host (internal) |
AirPrint Enabled |
Yes |
Office Machine Features |
Save to USB flash drive, scan to e-mail, save to network folder, pull-out keyboard, Mobile Printing |
Localisation |
English, German, French, Italian, Spanish / Europe |
Memory |
Standard Memory |
2 GB |
Max Supported Memory |
2.75 GB |
Supported Flash Memory |
USB flash drive |
Copying |
Max Copying Speed |
Up to 50 ppm (mono) / up to 50 ppm (colour) |
Max Copying Resolution |
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour) |
Max Document Enlargement |
400% |
Max Document Reduction |
25% |
Maximum Copies |
9999 |
Automatic Duplexing |
Yes |
Copying Features |
Collation copy |
Printing |
Max Printing Resolution |
Up to 1200 x 1200 dpi (mono) / up to 2400 x 1200 dpi (colour) |
Max Printing Speed |
Ink Palette Supported (Colours) |
Cyan, magenta, yellow, black |
Colour |
4-ink |
Printer Drivers / Emulations |
PCL 6, PostScript 3, PCL 5c, PDF 1.7 |
Yes |
First Print Out Time B/W |
7.1 sec |
First Print Out Time Colour |
7.3 sec |
Scanning |
Scan Element |
CIS |
Yes |
Optical Resolution |
600 dpi |
Grayscale Depth |
8-bit |
Colour Depth |
24-bit |
Fax Machine |
Max Transmission Speed |
33.6 Kbps |
Fax Resolutions |
300 x 300 dpi |
Fax Printing Resolution |
400 x 400 dpi |
Fax Machine Features |
Broadcast Transmission |
210 stations |
Document & Media Handling |
Min Original Size |
76 x 127 mm |
Max Original Size |
216 x 356 mm |
Original Type |
Sheets |
Document Feeder Capacity |
100 sheets |
Min Media Size |
76 x 127 mm |
Max Media Size |
A4/Legal |
Max Media Weight |
300 g/m² |
Supported Media Type |
Envelopes, plain paper, cards, labels, recycled paper, greeting cards, photo paper, bond paper, heavy-weight paper, light-weight paper, glossy photo paper, matte photo paper, satin photo paper, tri-fold paper, soft gloss photo paper |
Supported Media Sizes |
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 216 x 297 mm, JIS B5 (182 x 257 mm), 76 x 127 mm, 127 x 127 mm, 216 x 356 mm, JIS B6 (128 x 182 mm), 102 x 210 mm |
Supported Envelope Sizes |
International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm) |
Standard Media Capacity |
550 sheets |
Max Media Capacity |
2050 sheets |
Bypass Feeder Capacity |
50 sheets |
Output Trays Capacity |
300 sheets |
Document & Media Handling Details |
ADF - 100 sheets weight: 45 g/m² - 199 g/m² , Bypass tray - 50 sheets , Input tray - 500 sheets , Output tray - 300 sheets |
Speed Details |
Printing: up to 50 ppm (A4) - B/W , Printing: up to 50 ppm (A4) - colour , Printing: up to 25 ppm (A4) - B/W duplex , Printing: up to 25 ipm (A4) - colour duplex , Scanning: up to 45 ppm - B/W , Scanning: up to 45 ppm - colour , Copying: up to 50 ppm - B/W , Copying: up to 50 ppm - colour |
Connections |
Interfaces |
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 host - 4 pin USB Type A , 2 x USB 2.0 host (internal) , 1 x modem - RJ-11 |
Security Protocols & Features |
Kerberos, LDAP, SSL, Apple Bonjour, TLS, IPsec, 802.1x, EAP-TLS, PEAP |
Operating System Support |
MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2012 x64 Edition, MS Windows XP 64-bit Edition SP3 or later, MS Windows Server 2003 SP2 or later, MS Windows Server 2008 (32/64-bits), MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits), Ubuntu Linux 10 - 14, Apple Mac OS X 10.9 or later |
Software Included |
Drivers & Utilities |
Power |
Voltage Required |
AC 120/230 V (50/60Hz) |
Power Consumption Operational |
62 Watt |
Power Consumption Standby |
24 Watt |
Power Consumption Sleep |
8.5 Watt |
Miscellaneous |
Consumables Included |
1 x Cartridge (black) , 1 x Cartridge (cyan) , 1 x Cartridge (magenta) , 1 x Cartridge (yellow) |
Compliant Standards |
EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EN55024:2010, EMC 2004/108/EC, EN 55022:2010 Class A, CISPR 22:2008 |
Environmental Standards |
ENERGY STAR Certified |
Yes |
Blue Angel Compliant |
Yes |
Manufacturer Warranty |
Service & Support |
Limited warranty - parts and labour - 1 year - on-site - response time: next business day |
Dimensions & Weight |
Width |
53 cm |
Depth |
56.4 cm |
Height |
52.9 cm |
Weight |
32.3 kg |
Dimensions & Weight (Shipping) |
Shipping Weight |
40.4 kg |
Environmental Parameters |
Min Operating Temperature |
15 °C |
Max Operating Temperature |
30 °C |
Humidity Range Operating |
20 - 60% |
