HP PageWide Pro 477dw Colour Multifunction Printer
LIMITED TIME OFFER
CASHBACK
£609.08
in stock
Delivery:
Standard: 1-3 working days
Key features
  • Help protect your investment and extend capabilities as your needs grow, with a portfolio of solutions.
  • Minimise downtime with HP PageWide Technology that delivers reliable performance businesses demand.
  • Results you expect and lasting value – breakthrough total cost of ownership, the lowest in its class.
  • Wait less, do more with unmatched speeds – up to 55 ppm – and the fastest first-page printing in its class.
  • Type: Fax / copier / printer / scanner
  • Functionality: Copier, Fax, Printer, Scanner
  • Output Type: Colour
  • Technology: Ink-jet
  • Max Paper Size: A4 (210 x 297 mm), Legal (216 x 356 mm)
Product codes
Ultimate value and speed - HP PageWide Pro delivers the lowest total cost of ownership and fastest speeds in its class. Get quick two-sided scanning, plus best-in-class security features and energy efficiency.
• Multi-function - print, copy, scan, and more
• Get the lowest total cost of ownership and fastest speeds in its class. Get professional-quality color documents, fast two-sided scanning, plus best-in-class security features and energy efficiency
• For teams of 5–15 people printing; prints up to 6,000 pages/month
• Prints up to 70 pages per minute
Count on exceptional value and the results businesses need – print professional-quality colour documents for the lowest total cost of ownership in its class.
Results you expect and lasting value – breakthrough total cost of ownership, the lowest in its class. Print professional-quality colour on a variety of papers – perfect for office use. Print more pages and replace cartridges less often, using Original HP PageWide high-yield cartridges. Spend less time and budget on scheduled maintenance with streamlined HP PageWide Technology.
Minimise interruptions and downtime with efficient, reliable performance. Conserve resources and use less energy than laser printers, with HP PageWide Technology designed for today’s busy office.
Minimise downtime with HP PageWide Technology that delivers reliable performance businesses demand. Conserve with HP PageWide Technology – designed to use less energy than any MFP in its class. Get professional-quality colour documents and the performance you expect with Original HP PageWide cartridges.
Best-in-class print speeds, fast printing from sleep mode, and single-pass, two-sided scanning keep productivity on track. Documents are ready fast, so there’s less waiting.
Wait less, do more with unmatched speeds – up to 55 ppm – and the fastest first-page printing in its class. Get fast two-sided scanning directly to email and the cloud with this LDAP-enabled MFP. Manage tasks from a 10.9 cm (4.3-inch) touchscreen. Print Microsoft® Word and PowerPoint® files from USB. Print from your mobile device with Wi-Fi Direct and NFC touch-to-print technology – no network needed.
Help protect your fleet, data, and documents with best-in-class security and fleet management features. Help secure important information and get the tools you need to work efficiently and confidently.
Help protect your investment and extend capabilities as your needs grow, with a portfolio of solutions. Help ensure the security of confidential information. Enter a PIN at the device to retrieve your print job. Regulate colour use and reduce printing costs with HP Colour Access Control. Help keep your printer secure – from boot up to shutdown – with secure boot and secure code integrity validation.
Product Description HP PageWide Pro 477dw - multifunction printer - colour
Device Type Multifunction printer
Fax Type Plain paper
Localisation EMEA (excluding Israel, Saudi Arabia, South Africa)
Printing Technology Page wide array (colour)
Inkjet Technology 4-ink
Monthly Duty Cycle (max) 50000 pages
Recommended Monthly Volume 750 - 4500 pages
Max Copying Speed Up to 55 ppm (mono) / up to 55 ppm (colour)
Max Copying Resolution Up to 600 dpi (mono) / up to 600 dpi (colour)
Max Printing Speed Up to 55 ppm (mono) / up to 55 ppm (colour)
Max Printing Resolution Up to 1200 x 1200 dpi (mono) / up to 2400 x 1200 dpi (colour)
Max Fax Transmission Speed 33.6 Kbps
Fax Resolutions 203 x 98 dpi, 300 x 300 dpi, 200 x 200 dpi
Scanning 1200 x 1200 dpi
Display 4.3"
Original Size Legal (216 x 356 mm) (max)
Original Type Sheets
Document Feeder Capacity 50 sheets
Media Size 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type Envelopes, plain paper, cards, labels, recycled paper, greeting cards, photo paper, bond paper, heavy-weight paper, extra heavy-weight paper, light-weight paper, glossy photo paper, matte photo paper, glossy paper, tri-fold paper, matte paper, punched paper
Standard Media Capacity 500 sheets
Output Trays Capacity 300 sheets
Automatic Duplexing Yes (copying) Yes (printing) Yes (scanning)
Connection Availability Yes
Interface USB 2.0, LAN, Wi-Fi(n), NFC, USB 2.0 host
AirPrint Enabled Yes
Office Machine Features Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to folder, scan to network, HP EasyColor, Mobile Printing, access point mode, scan to SharePoint, scan to PC, scan to OCR
Power AC 120 V (50/60Hz)
Dimensions (WxDxH) 53 cm x 40.7 cm x 46.7 cm
Weight 22.15 kg
Environmental Standards ENERGY STAR Qualified
Manufacturer Warranty 1-year warranty
Accessories
Ink
Other bundles
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP PageWide Pro 477dw...
£609.08
