HP Pavilion 15.6" Full HD Ryzen 5 8GB 128GB Laptop
FREE DELIVERY
PRICE DROP
LIMITED TIME OFFER
HUGE SAVING! WAS £599.99!
£429.99
Delivery:
Standard: 1-3 working days
Express: Delivered tomorrow
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • Dual HP speakers, HP Audio Boost, and tuning by B&O PLAY deliver a rich, authentic audio experience.
  • Every detail was crafted for comfort and style—from the elevated keyboard to the new narrow bezel design.
  • Multitasking feels easy and fast with the performance of a powerful AMD processor.
  • Display Size: 15.6in
  • Processor Model: 2500U
  • Operating System: Windows 10 Home 64-bit Edition
  • Installed Memory: 8GB
  • Hard Drive Capacity: 128GB
Product codes
HP Pavilion Notebook 15-cw0983na
An ultrathin and light laptop loaded with performance and style.
Express yourself like never before with this stylish powerhouse built just for you. Slim enough to follow you anywhere, and powerful enough to make it through any day.
Accomplish more
All your activities become easier and faster than before with the latest processor and advanced graphics. Watch videos, edit photos, and connect to family and friends with all the power you need to get things done.
Thin. Always fits in.
A smooth metal finish gives this laptop a sharp, polished look - from the elevated keyboard to the new narrow bezel design, every detail was crafted for comfort and style.
A truly powerful audio experience
With dual HP speakers, HP Audio Boost, and custom tuning by the experts at B&O PLAY, you can experience rich, authentic audio. Let the sound move you.
Micro Edge display
By squeezing a larger screen into a smaller frame, this ultra-thin, barely visible bezel revolutionizes your display's appearance with a beautifully efficient design.
SD and Micro SD card reader
Simply insert an SD or Micro SD card and increase your device’s storage for more movies, photos, and music, or easily access any content you have stored on an existing card.
Specs
Performance
Operating system - Windows 10 Home 64
Processor - AMD Ryzen™ 5 2500U Quad-Core (2 GHz base frequency, up to 3.6 GHz burst frequency, 6 MB cache)
Memory - 8 GB DDR4-2400 SDRAM (2 x 4 GB)
Storage - 128 GB M.2 SSD
Graphics - Integrated: AMD Radeon™ Vega 8 Graphics
Audio - Bang & Olufsen, dual speakers, HP Audio Boost
Display - 39.6 cm (15.6") diagonal FHD SVA anti-glare micro-edge WLED-backlit (1920 x 1080)
Power - 45 W AC power adapter
Battery type - 3-cell, 41 Wh Li-ion; Supports battery fast charge: approximately 50% in 45 minutes
Target battery life - Up to 10 hours and 45 minutes estimated battery time
Network interface - Integrated 10/100/1000 GbE LAN
Wireless connectivity - Realtek RTL8821CE 802.11b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 4.2 Combo; MU-MIMO supported; Miracast compatible
Ports - 1 USB Type-C™ 3.1 Gen 1 (Data transfer only, up to 5Gb/s); 2 USB 3.1 Gen 1 (1 HP Sleep and Charge); 1 HDMI 1.4; 1 RJ-45; 1 headphone/microphone combo; 1 multi-format SD media card reader
Webcam - HP Wide Vision HD Camera with integrated dual array digital microphone
Additional Information
Part Number - 4XY39EA#ABU, UPC/EAN code: 193424837403
Energy efficiency compliance - ENERGY STAR® certified; EPEAT® Silver registered
Weight - 1.8 kg
Dimensions - 36.16 x 24.56 x 1.79 cm
Warranty - 1 year warranty
Keyboard - Full-size island-style keyboard with numeric keypad; HP Imagepad with multi-touch gesture support
Security management - Kensington NanoSaver™ security lock support
Sensors - Accelerometer
Product Description HP Pavilion 15-cw0983na - 15.6" - Ryzen 5 2500U - 8 GB RAM - 128 GB SSD
Product Type Notebook
Operating System Win 10 Home 64-bit
Processor AMD Ryzen 5 2500U / 2 GHz (3.6 GHz) / 6 MB Cache
Memory 8 GB DDR4 (2 x 4 GB)
Storage 128 GB SSD
Optical Drive No optical drive
Display 15.6" WLED 1920 x 1080 / Full HD
Graphics AMD Radeon Vega 8
Input Device Imagepad
Numeric Keypad Yes
Integrated Webcam Yes
Networking 802.11b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
Battery 3-cell - up to 10.75 hours
Features Accelerometer
Colour Mineral silver (cover), natural silver (keyboard frame and base), sandblasted anodised (cover), matte base and keyboard frame with pattern
Dimensions (WxDxH) 36.16 cm x 24.56 cm x 1.79 cm
Weight 1.8 kg
Environmental Standards ENERGY STAR Qualified
Manufacturer Warranty Limited warranty - parts and labour - 1 year - pick-up and return
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been used and shows signs of use
Ref: F9QN 041051
£316.62
product
Ref: F9QN 041051
Accessories
Packaging
Functional
Software
Manuals
£316.62
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP Pavilion 15.6" Full...
£429.99
