The ruggedly built HP ProBook Fortis provides reliability and performance for workers and students who need a PC they can work with throughout the day-wherever the day takes them. The large 14-inch diagonal screen, robust connectivity options, and collaboration tools enhance productivity and engagement from almost anywhere.
Product Description | HP ProBook Fortis 14 G9 Notebook - 14" - Celeron N5100 - 4 GB RAM - 128 GB SSD - UK | Product Type | Notebook | Operating System | Win 11 SE - English | Processor | Intel Celeron N5100 / 1.1 GHz (2.8 GHz) / 4 MB Cache | Memory | 4 GB DDR4 (provided memory is soldered) | Storage | 128 GB SSD - NVMe, HP Value | Display | 14" WLED 1366 x 768 / HD @ 60 Hz | Graphics | Intel UHD Graphics | Input Device | ClickPad | Keyboard | UK | Integrated Webcam | Yes | Networking | Bluetooth 5.0, 802.11a/b/g/n/ac/ax, Gigabit Ethernet | Battery | 3-cell | Security | Trusted Platform Module (TPM 2.0) Security Chip | Colour | Jack black | Dimensions (WxDxH) | 33.6 cm x 23 cm x 2.19 cm | Weight | 1.66 kg | Localisation | Language: English / region: United Kingdom | Environmental Standards | TCO Certified Notebooks 9, ENERGY STAR Qualified | Manufacturer Warranty | Limited warranty - parts and labour - 1 year |
General | |
Operating System | Windows 11 SE - English |
Processor / Chipset | |
CPU | Intel Celeron N5100 / 1.1 GHz |
Max Turbo Speed | 2.8 GHz |
Number of Cores | Quad-Core |
Cache | L3 - 4 MB |
Features | Intel Burst Technology |
Memory | |
RAM | 4 GB (provided memory is soldered) |
Technology | DDR4 SDRAM - non-ECC |
Speed | 2933 MHz |
Rated Speed | 3200 MHz |
Storage | |
Main Storage | 128 GB SSD M.2 2230 PCIe - NVM Express (NVMe), HP Value |
Display | |
Type | 14" |
LCD Backlight Technology | WLED backlight |
Resolution | 1366 x 768 (HD) |
V-Sync Rate at Max Res. | 60 Hz |
Widescreen | Yes |
Image Brightness | 250 cd/m² |
Colour Gamut | 45% NTSC |
Features | Ultra Slim Design, HD standard-viewing angle (SVA) eDP anti-glare, Micro Edge, narrow bezel bent |
Audio & Video | |
Graphics Processor | Intel UHD Graphics |
Camera | Yes - HD |
Video Resolutions | 720p |
Camera Features | Privacy shutter |
Sound | Stereo speakers, dual array microphone |
Input | |
Type | Keyboard, ClickPad |
Keyboard Layout | UK |
Features | Multi-touch clickpad, gesture function, pick resistant, spill-resistant |
Communications | |
Wireless | Bluetooth 5.0, 802.11a/b/g/n/ac/ax |
Wireless Controller | Intel Wi-Fi 6 AX 201 |
Network Interface | Gigabit Ethernet |
Ethernet Controller | Realtek RTL8111HSH-CG |
Features | Wake-on-LAN (WOL), dual stream (2x2), MU-MIMO |
Battery | |
Technology | 3-cell lithium polymer |
Capacity | 42 Wh |
AC Adapter | |
Input | AC 90-265 V (50/60 Hz) |
Output | 45 Watt, 19.5 V |
Connections & Expansion | |
Interfaces | 2 x USB 3.2 Gen 1 , USB-C 3.2 Gen 1 (supports DisplayPort 1.2 Alt Mode) (Power Delivery) , LAN , Headphone/microphone combo jack , HDMI |
Software | |
Software Included | HP Support Assistant, HP Hotkey Support, HP Client Catalogue (free download), HP Driver Packs, HP PC Hardware Diagnostics, HP MAC Address Manager, HP Notifications, HP Connection Optimizer, HP Classroom Manager, HP Privacy Settings, HP QuickDrop, HP Client Management Script Library (free download), HP Image Assistant Gen5, HP Wake on WLAN, myHP, Touchpoint Customiser for Commercial, HSA Fusion for Commercial, HSA Telemetry for Commercial, HP Easy Clean, HP Smart Support, HP Connect for Microsoft Endpoint Manager, HP Patch Assistant (free download), HP Manageability & Integration Kit Gen4 (free download) |
Miscellaneous | |
Features | BIOS Absolute Persistence, HP Automatic Drive Lock, HP DriveLock, BIOS Update via Network, HP Sure Sense, HP Secure Erase, HP BIOSphere Gen 6, HP Sure Start Gen 7 |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington nano security slot |
Included Accessories | HP 45 Watt Smart nPFC AC Adapter |
Compliant Standards | CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FIPS 140-2 Level 2, FCC, A-Tick, ICES, Common Criteria EAL4+, KC, CIT, low halogen, ICCP, BNCI |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 1.66 kg |
Environmental Standards | |
TCO Certified | TCO Certified Notebooks 9 |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 1 year |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
Shock Tolerance (operating) | 40 g @ 2 ms half-sine |
Shock Tolerance (non-operating) | 240 g @ 2 ms half-sine |
Vibration Tolerance (operating) | 0.75 g @ RMS (random) |
Vibration Tolerance (non-operating) | 1.5 g @ RMS (random) |
Get more from your purchase from one of our essential accessories
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
