HP Pro Tablet 408 Active Pen
Key features
  • Once in range, your tablet detects the pen and cues you where to place it onscreen. Erase, highlight, and click on your content with the two convenient side buttons.
  • Rest easy with a one-year limited warranty.
  • Use the pen to write or draw onscreen or interact with your touch applications. Integrated pressure sensors help you control the width of your drawn lines.
Product codes
Maximize your mobile productivity with the HP Pro Tablet 408 Active Pen, which allows you to write naturally on your HP Pro Tablet 408 G1 screen and navigate touchscreen activities.
Product Description HP Active Pen - digital pen
Device Type Digital pen
Dimensions (WxDxH) 0.98 cm x 0.98 cm x 14.55 cm
Weight 25 g
Battery AAAA type
OS Required Windows 8 / 8.1
Manufacturer Warranty 1-year warranty
Designed For Pro Tablet 10 EE G1, 408 G1; Spectre Pro x360 G2; x2 210, 210 G2
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP Pro Tablet 408 Acti...
