Full-featured, thin, and light, the HP ProBook 470 lets professionals stay productive in the office and on the go. Stylish design, linear precision, and subtle curvature plus optional Quad Core performance and long battery life make this ProBook essential for today's workforce.
Product Description | HP ProBook 470 G5 - 17.3" - Core i7 8550U - 8 GB RAM - 256 GB SSD + 1 TB HDD - UK | Product Type | Notebook | Operating System | Win 10 Pro 64-bit - English | Processor | Intel Core i7 (8th Gen) 8550U / 1.8 GHz (4 GHz) / 8 MB Cache | Memory | 8 GB DDR4 (1 x 8 GB) | Storage | 256 GB SSD NVMe, TLC, HP Value + 1 TB HDD / 5400 rpm | Optical Drive | No optical drive | Display | 17.3" LED backlight 1920 x 1080 / Full HD | Graphics | Intel UHD Graphics 620 / NVIDIA GeForce 930MX | Video Memory | 2 GB DDR3 SDRAM | Input Device | ClickPad | Keyboard | UK | Numeric Keypad | Yes | Integrated Webcam | Yes | Networking | Gigabit Ethernet | Battery | 3-cell | Security | Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader | Dimensions (WxDxH) | 41.38 cm x 27.6 cm x 2.25 cm | Weight | 2.5 kg | Localisation | Language: English / region: United Kingdom | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | Limited warranty - 1 year , Limited warranty - battery - 1 year |
General | |
Operating System | Windows 10 Pro 64-bit Edition - English |
Processor / Chipset | |
CPU | Intel Core i7 (8th Gen) 8550U / 1.8 GHz |
Max Turbo Speed | 4 GHz |
Number of Cores | Quad-Core |
Cache | L3 - 8 MB |
64-bit Computing | Yes |
Features | Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache |
Memory | |
RAM | 8 GB (1 x 8 GB) |
Max RAM Supported | 32 GB |
Technology | DDR4 SDRAM |
Speed | 2400 MHz / PC4-19200 |
Rated Speed | 2400 MHz |
Form Factor | SO-DIMM 260-pin |
Slots Qty | 2 |
Empty Slots | 1 |
Storage | |
Main Storage | 256 GB SSD - (M.2 2280) PCIe - NVM Express (NVMe), triple-level cell (TLC), HP Value |
Secondary Storage | 1 TB HDD SATA / 5400 rpm |
Display | |
Type | 17.3" - IPS |
LCD Backlight Technology | LED backlight |
Resolution | 1920 x 1080 (Full HD) |
Widescreen | Yes |
Image Brightness | 220 cd/m² |
Features | Full HD ultra wide-viewing angle (UWVA) eDP anti-glare, 45% sRGB |
Keyboard Name | HP Premium |
Audio & Video | |
Multi-GPU Configuration | 1 single GPU card / integrated GPU |
Graphics Processor | Intel UHD Graphics 620 / NVIDIA GeForce 930MX |
Camera | Yes - 720p |
Sound | Stereo speakers, dual array microphone |
Input | |
Type | Keyboard, ClickPad |
Keyboard Layout | UK |
Features | Spill-resistant, multi-touch clickpad, ClickPad with gesture support |
Communications | |
Network Interface | Gigabit Ethernet |
Ethernet Controller | Realtek RTL8111HSH |
Remote Management Protocol | SNMP 2 |
Features | Wake-on-LAN (WOL) |
Battery | |
Technology | 3-cell Lithium Ion |
Capacity | 48 Wh |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 65 Watt |
Connections & Expansion | |
Interfaces | USB 2.0 (powered) , 2 x USB 3.1 Gen 1 , USB-C 3.1 Gen 1/DisplayPort (Power Delivery) , HDMI , Headphone/microphone combo jack , LAN , VGA |
Memory Card Reader | Yes (SD Card, SDHC Card, SDXC Card) |
Software | |
Software Included | HP Recovery Manager, HP Support Assistant, HP ePrint, HP Hotkey Support, HP Velocity, HP Secure Erase, HP Drive Packs (free download), HP Client Catalog, HP BIOS Config Utility, HP 3D DriveGuard 6, HP JumpStart, HP Noise Cancellation, HP System Software Manager, HP LAN-WLAN Protection, HP Client Security Suite Gen3, HP JetAdvantage, HP Wireless Wakeup, HP Management Integration Kit for Microsoft System Center Configuration Manager (free download), HP Connection Optimizer, HP BIOSphere Gen4 |
Miscellaneous | |
Features | HP DriveLock |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Included Accessories | Power adapter |
Compliant Standards | CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, A-Tick, ICES, KC, CIT |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 2.5 kg |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year , Limited warranty - battery - 1 year |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
Shock Tolerance (operating) | 40 g @ 2 ms half-sine pulse |
Shock Tolerance (non-operating) | 200 g @ 2 ms half-sine pulse |
Vibration Tolerance (operating) | 0.75 g @ RMS (random) |
Vibration Tolerance (non-operating) | 1.5 g @ RMS (random) |
