General |
Product Type |
Notebook |
Operating System |
Windows 10 Pro 64-bit Edition - English |
Processor / Chipset |
CPU |
Intel Core i5 (6th Gen) 6200U / 2.3 GHz |
Max Turbo Speed |
2.8 GHz |
Number of Cores |
Dual-Core |
Cache |
3 MB |
64-bit Computing |
Yes |
Features |
Intel Turbo Boost Technology 2.0 |
Memory |
RAM |
4 GB (1 x 4 GB) |
Max RAM Supported |
16 GB |
Technology |
DDR4 SDRAM |
Speed |
2133 MHz / PC4-17000 |
Rated Speed |
2133 MHz |
Form Factor |
SO-DIMM 260-pin |
Slots Qty |
2 |
Empty Slots |
1 |
Storage |
Main Storage |
500 GB HDD SATA 6Gb/s / 7200 rpm |
Optical Drive |
DVD±RW (±R DL) / DVD-RAM |
Display |
Type |
14" |
LCD Backlight Technology |
WLED backlight |
Resolution |
1366 x 768 (HD) |
Widescreen |
Yes |
Image Brightness |
220 cd/m² |
Features |
HD standard-viewing angle (SVA) eDP anti-glare |
Audio & Video |
Graphics Processor |
Intel HD Graphics 520 |
Camera |
Yes - 720p |
Video Resolutions |
1280 x 720 |
Frame Rate |
30 frames per second |
Camera Features |
Low light enhancement |
Sound |
Stereo speakers, two microphones |
Compliant Standards |
High Definition Audio, DTS SOUND+ |
Input |
Type |
Keyboard, touchpad, pointing stick |
Keyboard Layout |
UK |
Features |
Volume control, spill-resistant, touchpad with gesture support |
Communications |
Wireless |
Bluetooth 4.0, 802.11a/b/g/n/ac |
Bluetooth Class |
Class 2 |
Wireless Controller |
Intel Dual Band Wireless-AC 7265 - PCI Express Mini Card (M.2) |
Network Interface |
Gigabit Ethernet |
IEEE 802.3ab, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED |
Battery |
Technology |
3-cell Lithium Ion |
Capacity |
48 Wh |
Run Time |
Up to 10 hours |
AC Adapter |
Output |
45 Watt |
Connections & Expansion |
Interfaces |
USB-C , USB 3.0 , LAN , Dock , Headphone/microphone combo jack , DisplayPort , VGA , USB 3.0 (charging) |
Memory Card Reader |
Yes (SD Card, SDHC Card, SDXC Card) |
Software |
Software Included |
CyberLink Power2Go, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, CyberLink PowerDVD BD Edition, Foxit PhantomPDF Express, Windows Defender, HP Client Security, HP Systems Software Manager (free download), HP Secure Erase, HP BIOSphere, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Client Catalogue (free download), HP CIK for Microsoft SCCM (free download), HP 3D DriveGuard, HP Noise Reduction Software, HP Mobile Connect Pro |
Miscellaneous |
Case Material |
Polycarbonate ABS |
Dockable |
Yes |
Security |
Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader |
Features |
HP 3D DriveGuard, soft-touch surface, HP BIOS Protection, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security, Pre-boot Authentication |
Theft/Intrusion Protection |
Security lock slot (cable lock sold separately) |
Security Slot Type |
Kensington security slot |
Included Accessories |
Power adapter |
RoHS, WEEE, Common Criteria EAL4+, low halogen |
Localization |
Language: English / region: United Kingdom |
Dimensions & Weight |
Dimensions (WxDxH) |
34 cm x 23.7 cm x 2.7 cm |
Weight |
1.95 kg |
Environmental Standards |
ENERGY STAR Certified |
Yes |
Manufacturer Warranty |
Service & Support |
Limited warranty - parts and labour - 1 year , Limited warranty - battery - 1 year |
