Designed to fit the modern workspace now and in the future, the stylishly designed, reliable, and secure HP ProDesk 400 MT is a powerful PC with scalable performance that can grow with your business.
Product Description | HP ProDesk 400 G5 - micro tower - Core i5 8500 3 GHz - 8 GB - 256 GB - UK | Type | Personal computer - micro tower | Localisation | Language: English / region: United Kingdom | Processor | 1 x Intel Core i5 (8th Gen) 8500 / 3 GHz (4.1 GHz) (6-core) | Processor Main Features | Intel Turbo Boost Technology 2, Intel Smart Cache | Cache Memory | 9 MB | Cache Per Processor | 9 MB | RAM | 8 GB (installed) / 16 GB (max) - DDR4 SDRAM - non-ECC | Storage Controller | SATA (SATA 6Gb/s) | Hard Drive | 1 x SSD 256 GB - PCI Express - NVM Express (NVMe) | Optical Storage | DVD-Writer | Graphics Controller | Intel UHD Graphics 630 | Audio Output | Stereo | Networking | GigE | Keyboard | UK | Power | AC 120/230 V (50/60 Hz) | OS Provided | Windows 10 Pro 64-bit Edition | Dimensions (WxDxH) | 17 cm x 27.4 cm x 33.8 cm | Weight | 5.47 kg | Manufacturer Warranty | Limited warranty - parts and labour - 1 year - on-site |
General | |
Type | Personal computer |
Product Form Factor | Micro tower |
Embedded Security | Trusted Platform Module (TPM 2.0) Security Chip |
Processor / Chipset | |
CPU | Intel Core i5 (8th Gen) 8500 / 3 GHz |
Max Turbo Speed | 4.1 GHz |
Number of Cores | 6-core |
CPU Qty | 1 |
Max CPU Qty | 1 |
CPU Upgradability | Upgradable |
Chipset Type | Intel B360 |
Cache Memory | |
Installed Size | 9 MB |
RAM | |
Installed Size | 8 GB / 16 GB (max) |
Technology | DDR4 SDRAM - non-ECC |
Effective Memory Speed | 2666 MHz |
Rated Memory Speed | 2666 MHz |
Form Factor | DIMM 288-pin |
Slots | 2 (Total) / 1 (empty) |
Features | Unbuffered, dual channel memory architecture |
Configuration Features | 1 x 8 GB |
Hard Drive | |
Type | SSD |
Capacity | 1 x 256 GB |
Interface Type | PCI Express |
Features | NVM Express (NVMe) |
Storage Controller | |
Type | 1 x SATA |
Controller Interface Type | SATA 6Gb/s |
Optical Storage | |
Type | DVD-Writer - SATA |
Monitor | |
Monitor Type | None. |
Graphics Controller | |
Graphics Processor | Intel UHD Graphics 630 |
Video Interfaces | VGA, DisplayPort |
Audio Output | |
Sound Output Mode | Stereo |
Max Sampling Rate | 192 kHz |
Compliant Standards | High Definition Audio |
Input Device | |
Type | Mouse, keyboard |
Keyboard | |
Interface | USB |
Localization & Layout | UK |
Mouse | |
Technology | Optical |
Interface | USB |
Networking | |
Interface (Bus) Type | PCI Express 1.1 x1 |
Ethernet Controller | Realtek RTL8111HSH-CG |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet |
Remote Management Protocol | SNMP 2 |
Features | Wake on LAN (WoL), ACPI support, PXE support, auto-uplink (auto MDI/MDI-X) |
Compliant Standards | IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az |
Expansion / Connectivity | |
Bays | 1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 1 (free) x internal 3.5" , 1 (total) / 1 (free) x internal 2.5" / 3.5" shared , 1 (total) / 1 (free) x external |
Slots | 2 (total) / 2 (free) x PCIe 3.0 x1 - full-height , 1 PCIe 3.0 x16 , 1 M.2 Card - 2280/2230 (x1 mode) , 1 (total) / 1 (free) x M.2 Card - 2230 (x1 mode) |
Interfaces | 4 x USB 3.1 Gen 1 (2 front, 2 rear) , 4 x USB 2.0 , 1 x VGA , 1 x DisplayPort , 1 x headphones/microphone , 1 x audio line-in , 1 x audio line-out , 1 x LAN (Gigabit Ethernet) - RJ-45 , 1 x PS/2 keyboard / mouse |
Miscellaneous | |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Compliant Standards | ACPI, FIPS 140-2 Level 2, RoHS, WEEE, Common Criteria EAL4+ |
Power | |
Device Type | Power supply |
Nominal Voltage | AC 120/230 V (50/60 Hz) |
Power Provided | 180 Watt |
Efficiency | 90% |
Power Factor Correction | Yes (active) |
Operating System / Software | |
OS Provided | Windows 10 Pro 64-bit Edition English |
Software | HP Recovery Manager, HP Support Assistant, HP Hotkey Support, HP Spare Key, Windows Defender, HP Systems Software Manager (free download), HP Velocity, HP Secure Erase, HP Security Manager, HP Credential Manager, HP Client Catalogue (free download), HP Driver Packs, HP BIOS Config Utility, HP Device Access Manager, HP JumpStart, HP Workwise, HP Noise Cancellation, Native Miracast, HP Wireless Wakeup, HP PhoneWise, HP Sure Click, HP Manageability & Integration Kit Gen2, HP Client Security Suite Gen4, Power On Authentication |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 1 year - on-site |
Dimensions & Weight | |
Width | 17 cm |
Depth | 27.4 cm |
Height | 33.8 cm |
Weight | 5.47 kg |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
