General |
Type |
Personal computer |
Product Form Factor |
Mini desktop |
Built-in Devices |
Speaker |
Embedded Security |
Trusted Platform Module (TPM 2.0) Security Chip |
Localisation |
Language: English / region: United Kingdom |
Processor / Chipset |
CPU |
Intel Core i3 (9th Gen) 9100T / 3.1 GHz |
Max Turbo Speed |
3.7 GHz |
Number of Cores |
Quad-Core |
CPU Qty |
1 |
Max CPU Qty |
1 |
Chipset Type |
Intel Q370 |
Cache Memory |
Installed Size |
6 MB |
Cache Per Processor |
6 MB |
RAM |
Installed Size |
8 GB / 64 GB (max) |
Technology |
DDR4 SDRAM |
Effective Memory Speed |
2666 MHz |
Rated Memory Speed |
2666 MHz |
Form Factor |
SO-DIMM 260-pin |
Slots |
2 (Total) / 1 (empty) |
Configuration Features |
1 x 8 GB |
Hard Drive |
Type |
HDD |
Capacity |
1 x 1 TB |
SSD Cache |
3D Xpoint (Optane) - 16 GB |
Interface Type |
SATA 6Gb/s |
Spindle Speed |
7200 rpm |
Storage Controller |
Type |
1 x SATA |
Optical Storage |
Type |
No optical drive |
Monitor |
Monitor Type |
None. |
Graphics Controller |
Graphics Processor |
Intel UHD Graphics 630 |
Video Interfaces |
VGA, DisplayPort |
HDCP Compatible |
Yes |
Audio Output |
Sound Output Mode |
Stereo |
Max Sampling Rate |
192 kHz |
Compliant Standards |
High Definition Audio |
Input Device |
Type |
Keyboard |
Keyboard |
Keyboard Name |
HP Business Slim Keyboard |
Interface |
USB |
Localization & Layout |
UK |
Networking |
Data Link Protocol |
Ethernet, Fast Ethernet, Gigabit Ethernet |
Remote Management Protocol |
SNMP 2 |
Expansion / Connectivity |
Bays |
1 (total) / 0 (free) x internal 2.5" |
Slots |
1 (total) / 1 (free) x M.2 Card - 2230 (x1 mode) , 1 (total) / 1 (free) x M.2 Card - 2280/2230 (x4 mode) |
Interfaces |
1 x USB-C 3.1 Gen 2 (1 in front) (charging) , 3 x USB 3.1 Gen 2 (1 front, 2 rear) , 3 x USB 3.1 Gen 1 (1 front, 2 rear) (two of them with wake functionality, one of them is charging) , 1 x headphones (1 in front) , 2 x DisplayPort , 1 x LAN (Gigabit Ethernet) , 1 x headphones/microphone (1 in front) , 1 x VGA |
Miscellaneous |
Theft/Intrusion Protection |
Security lock slot (cable lock sold separately), padlock loop |
Security Slot Type |
Kensington security slot |
ACPI, RoHS, WEEE, Common Criteria EAL4+, low halogen |
Power |
Device Type |
Power adapter |
Nominal Voltage |
AC 120/230 V (50/60 Hz) |
Power Provided |
65 Watt |
Efficiency |
88% (115VAC) / 89% (230VAC) |
Operating System / Software |
OS Provided |
Windows 10 Pro 64-bit Edition English |
Dimensions & Weight |
Width |
17.7 cm |
Depth |
17.5 cm |
Height |
3.42 cm |
Weight |
1.25 kg |
Dimensions & Weight (Shipping) |
Shipping Width |
49.7 cm |
Shipping Depth |
12.8 cm |
Shipping Height |
22.3 cm |
Shipping Weight |
2.97 kg |
Environmental Parameters |
Min Operating Temperature |
5 °C |
Max Operating Temperature |
35 °C |
Humidity Range Operating |
5 - 90% |
