HP ProDisplay Companion Stand
Key features
  • Find your best viewing position with adjustable tilt settings.
  • Get the reassurance of a one-year parts replacement limited warranty.
  • Simply attach your HP ProDisplay head to the front of the stand and attach your HP Desktop Mini, Chromebox, Thin Client or USDT to the back of the monitor using the integrated HP Quick Release mounting plate.
  • Store your PC power brick out of the way on the built-in tray. Use the optional HP Security Lock to help deter theft or tampering of the PC or display.
Product codes
Maximize small work spaces with an affordable HP ProDisplay Companion Stand, which enables you to create a compact desktop solution by combining an HP ProDisplay Monitor with your choice of platform.
HP Companion Stand - monitor stand
Monitor stand
23.6 cm x 19.2 cm x 11.9 cm
850 g
HP 260 G2; ProDisplay P191, P221
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP ProDisplay Companio...
