HP ProDisplay P17A - LED monitor - 17" - 1280 x 1024
Key features
  • Get a stable product lifecycle and minimum one-year lifespan at a price point that’s easy on your wallet. Be confident in the improved reliability of a monitor that has been through its paces with HP quality standard testing.
  • Get crisp, clear views of your documents and e-mail with 1280 x 1024 resolution and 5 ms response time on a 43,18 cm (17'') diagonal screen. Quickly connect to your devices with a VGA input. Keep your work space tidy with the internal power supply.
  • Keep the 5:4 aspect ratio that your business-specific enterprise and public sector applications are designed to work with.
  • Reduce power consumption and lower costs with an energy efficient design that is ENERGY STAR® and TCO qualified and EPEAT® 2019 registered. Includes mercury-free display backlights, low halogen design, and arsenic-free display glass.
Product codes
Get productive with an essential business monitor featuring solid performance, a 5:4 aspect ratio for business-specific applications, and energy savings–all at an attractive price point. Grow with a stylish monitor backed by HP reliability, a stable lifecycle, and HP accessory compatibility.
Product Description HP ProDisplay P17A - LED monitor - 17"
Device Type LED-backlit LCD monitor - 17"
Panel Type TN
Native Resolution 1280 x 1024 at 60 Hz
Pixel Pitch 0.264 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1
Response Time 5 ms
Colour Support 16.7 million colours
Input Connectors VGA
Display Position Adjustments Tilt
Screen Coating Anti-glare
Colour Black
Dimensions (WxDxH) - with stand 37.72 cm x 20.63 cm x 38.72 cm
Weight 3.72 kg
Localisation English / United Kingdom
Environmental Standards TCO Certified Displays 7, ENERGY STAR Qualified
Compliant Standards Plug and Play, FCC Class B certified, TUV, VCCI, BSMI CNS 13438 Class B, CCIB, cUL, GS, EN55022 Class B, CCEE, FCC Part 15, EN55024 Class B, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, ISO 9241-307, KCC, Energy-using Products (EuP) Lot 6, WEEE, CISPR, GEEA, CSA C22.2 No. 60950-1, KC, CEL
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP ProDisplay P17A - L...
