HP ProDisplay P223 1920 x 1080 5ms VGA DP LED 21.5" Mon...
HP ProDisplay P223 1920 x 1080 5ms  VGA DP LED 21.5" Monitor
£107.56
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Attach your HP PC or select HP Thin Client directly behind the display.
  • Experience stunning FHD picture quality, ultra-fast graphics refresh, and vivid colors with DisplayPortâ„¢.
  • Share your content in crisp, clear color on the 54.6 cm (21.5") diagonal screen with 1920 x 1080 resolution, and 3000:1 contrast ratio.
  • Diagonal Size: 21.5in
  • Max Resolution: 1920 x 1080
  • Response Time: 5ms
  • Speakers: None
  • Interfaces: DisplayPort, VGA (HD-15)
Product codes
Put your HP Pro PC content front and center on an ample 21.5-inch diagonal FHD screen with the HP ProDisplay P223 21.5-inch monitor.
Product Description HP ProDisplay P223 - LED monitor - Full HD (1080p) - 21.5"
Device Type LED-backlit LCD monitor - 21.5"
Panel Type VA
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Pixel Pitch 0.248 mm
Brightness 250 cd/m²
Contrast Ratio 3000:1 / 5000000:1 (dynamic)
Response Time 5 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors VGA, DisplayPort
Display Position Adjustments Tilt
Screen Coating Anti-glare
Colour Black
Dimensions (WxDxH) - with stand 51.5 cm x 19.12 cm x 38.9 cm
Weight 3.5 kg
Localisation English / United Kingdom
Pricing Type Promo
Environmental Standards ENERGY STAR Qualified
Compliant Standards Plug and Play, VCCI, BSMI, NOM, TUV S, CB, CCC, PSB, FCC, KCC, KC, CECP, EPA, TCO Displays, ISC, CEL Grade 2, SEPA, ICE
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP ProDisplay P223 192...
£107.56
