Project your HP Pro PC content to a 58,4 cm (23") diagonal display with the HP ProDisplay P232 Monitor, which has a sleek design, essential presentation features, and advanced connectivity for your everyday business productivity, all at a highly affordable price point.
Product Description | HP ProDisplay P232 - LED monitor - Full HD (1080p) - 23" | Device Type | LED-backlit LCD monitor - 23" | Panel Type | TN | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Pixel Pitch | 0.265 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 5000000:1 (dynamic) | Response Time | 5 ms (On/Off) | Colour Support | 16.7 million colours | Input Connectors | VGA, DisplayPort | Display Position Adjustments | Tilt | Screen Coating | Anti-glare | Colour | Black | Dimensions (WxDxH) - with stand | 54.86 cm x 18.5 cm x 40.83 cm | Weight | 4 kg | Localisation | English / United Kingdom | Environmental Standards | TCO Certified Displays 7, ENERGY STAR Qualified | Compliant Standards | Plug and Play, CSA, UL, TUV, TUV GS, VCCI, BSMI, NOM, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, ICES, S Mark, MEPS, KC, CECP, CEL, EAC, CEL Grade 1, ISC, RCM, SEPA | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 23" |
Viewable Size | 23" |
Panel Type | TN |
Pixel Per Inch | 96 |
Vertical Refresh Rate | 50 - 60 Hz |
Horizontal Refresh Rate | 24 - 80 kHz |
Video Bandwidth | 170 MHz |
Horizontal Viewing Angle | 170 |
Vertical Viewing Angle | 160 |
Backlight Technology | WLED |
Controls & Adjustments | Brightness, contrast |
OSD Languages | Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese |
Features | HDCP, 72% colour gamut |
Colour | Black |
Dimensions (WxDxH) | 54.86 cm x 18.5 cm x 40.83 cm - with stand |
Weight | 4 kg |
Connectivity | |
Interfaces | VGA , DisplayPort (HDCP) |
Mechanical | |
Tilt Angle | -5/+25 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | VESA interface support, dual monitor support |
Cables Included | 1 x VGA cable - 1.8 m , 1 x DisplayPort cable - 1.8 m |
Backlight Life | 30,000 hours |
Power | |
Power Supply | Internal |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Operational | 24 Watt |
Power Consumption Stand by | 0.5 Watt |
Software / System Requirements | |
Included Software | Drivers & Utilities, HP Display Assistant |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 54.86 cm - depth: 18.5 cm - height: 40.83 cm - weight: 4 kg , Without stand - width: 54.86 cm - depth: 5.5 cm - height: 34.63 cm - weight: 3.4 kg |
Environmental Standards | |
ENERGY STAR Certified | Yes |
TCO Certified | TCO Certified Displays 7 |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 3 years - on-site |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 20 - 80% (non-condensing) |
