HP ProDisplay P232 23" 1920x1080 5ms VGA DisplayPort LED...
HP ProDisplay P232 23" 1920x1080 5ms VGA DisplayPort LED Monitor
£114.67
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Attach your HP PC or select HP Thin Client directly behind the display.
  • Experience stunning FHD picture quality, ultra-fast graphics refresh, and vivid colors with DisplayPort.
  • Reduce power consumption and help lower your costs with an energy-efficient design.
  • Diagonal Size: 23in
  • Max Resolution: 1920 x 1080
  • Response Time: 5ms
  • Speakers: None
  • Interfaces: DisplayPort, VGA (HD-15)
Product codes
Project your HP Pro PC content to a 58,4 cm (23") diagonal display with the HP ProDisplay P232 Monitor, which has a sleek design, essential presentation features, and advanced connectivity for your everyday business productivity, all at a highly affordable price point.
Product Description HP ProDisplay P232 - LED monitor - Full HD (1080p) - 23"
Device Type LED-backlit LCD monitor - 23"
Panel Type TN
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Pixel Pitch 0.265 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 5000000:1 (dynamic)
Response Time 5 ms (On/Off)
Colour Support 16.7 million colours
Input Connectors VGA, DisplayPort
Display Position Adjustments Tilt
Screen Coating Anti-glare
Colour Black
Dimensions (WxDxH) - with stand 54.86 cm x 18.5 cm x 40.83 cm
Weight 4 kg
Localisation English / United Kingdom
Environmental Standards ENERGY STAR Qualified
Compliant Standards Plug and Play, CSA, UL, TUV, TUV GS, VCCI, BSMI, NOM, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, ICES, S Mark, MEPS, TCO Certified Edge, KC, CECP, CEL, EAC, CEL Grade 1, ISC, RCM, SEPA
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP ProDisplay P232 23"...
£114.67
