Easy-to-deploy, sleek, and feature-rich, the HP ProOne 400 20" All-in-One PC with business-class collaboration and security features is a sound investment.
Product Description | HP ProOne 400 G3 - all-in-one - Core i5 7500T 2.7 GHz - 4 GB - 1 TB - LED 20" - UK | Type | Personal computer - all-in-one | Localisation | Language: English / region: United Kingdom | Processor | 1 x Intel Core i5 (7th Gen) 7500T / 2.7 GHz (3.3 GHz) (Quad-Core) | Processor Main Features | Hyper-Threading Technology, Intel Smart Cache | Cache Memory | 6 MB | Cache Per Processor | 6 MB | RAM | 4 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC - PC4-19200 | Storage Controller | SATA (SATA 6Gb/s) | Hard Drive | 1 x 1 TB - SATA 6Gb/s - 7200 rpm | Optical Storage | DVD-Writer | Card Reader | Yes | Monitor | 20" - LED - 1600 x 900 (HD+) - 16:9 | Graphics Controller | Intel HD Graphics 630 Dynamic Video Memory Technology | Camera | Yes | Audio Output | Stereo | Networking | GigE, 802.11a, 802.11b/g/n, 802.11ac, Bluetooth 4.2 | Keyboard | UK | Power | AC 120/230 V (50/60 Hz) | OS Provided | Windows 10 Home 64-bit Edition | Dimensions (WxDxH) | 49.77 cm x 5.8 cm x 34.7 cm | Weight | 5.51 kg | Environmental Standards | ENERGY STAR Qualified |
General | |
Type | Personal computer |
Product Form Factor | All-in-one - with height-adjustable stand |
Processor / Chipset | |
CPU | Intel Core i5 (7th Gen) 7500T / 2.7 GHz |
Max Turbo Speed | 3.3 GHz |
Number of Cores | Quad-Core |
CPU Qty | 1 |
Max CPU Qty | 1 |
Chipset Type | Intel H270 |
Cache Memory | |
Installed Size | 6 MB |
RAM | |
Installed Size | 4 GB / 32 GB (max) |
Technology | DDR4 SDRAM - non-ECC |
Effective Memory Speed | 2400 MHz |
Rated Memory Speed | 2400 MHz |
Memory Specification Compliance | PC4-19200 |
Form Factor | SO-DIMM 260-pin |
Slots | 2 (Total) / 1 (empty) |
Features | Unbuffered |
Configuration Features | 1 x 4 GB |
Hard Drive | |
Type | HDD |
Capacity | 1 x 1 TB |
Interface Type | SATA 6Gb/s |
Spindle Speed | 7200 rpm |
Storage Controller | |
Type | 1 x SATA |
Controller Interface Type | SATA 6Gb/s |
Optical Storage | |
Type | DVD-Writer - SATA |
Card Reader | |
Type | Card reader |
Supported Flash Memory Cards | SD Memory Card, SDHC Memory Card, SDXC Memory Card |
Monitor | |
Monitor Type | LED - IPS |
Diagonal Size | 20" |
Native Resolution | 1600 x 900 (HD+) |
Widescreen Display | Yes |
Image Aspect Ratio | 16:9 |
Horizontal Viewing Angle | 170 |
Vertical Viewing Angle | 160 |
Pixel Pitch | 0.276 mm |
Image Brightness | 250 cd/m² |
Image Contrast Ratio | 1000:1 |
Monitor Features | HD+ anti-glare |
Graphics Controller | |
Graphics Processor | Intel HD Graphics 630 Dynamic Video Memory Technology |
Video Interfaces | DisplayPort |
Audio Output | |
Sound Output Mode | Stereo |
Max Sampling Rate | 192 kHz |
Compliant Standards | High Definition Audio, DTS Studio Sound |
Speakers Included | 2 x right / left channel |
Camera | |
Camera | Yes |
Resolution (MP) | 1 Megapixel |
Resolution | 1920 x 1080 |
Input Device | |
Type | Mouse, keyboard |
Keyboard | |
Keyboard Name | HP Business Slim Keyboard |
Interface | USB |
Localization & Layout | UK |
Mouse | |
Technology | Optical |
Interface | USB |
Audio Input | |
Type | Two microphones |
Networking | |
Ethernet Controller | Realtek RTL8111HSH |
Wireless LAN Supported | Yes |
Wireless NIC | Intel Dual Band Wireless-AC 7265 |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2 |
Features | Dual stream (2x2) |
Compliant Standards | IEEE 802.3, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2 |
Expansion / Connectivity | |
Bays | 1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 1 (free) x external , 1 (total) / 0 (free) x internal 2.5" |
Slots | 1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x SO-DIMM 260-pin , 1 (total) / 0 (free) x M.2 Card - 2230 , 1 (total) / 1 (free) x M.2 Card - 2280/2230 |
Interfaces | 3 x USB 3.1 , 2 x USB 2.0 (2 rear) , 1 x DisplayPort , 1 x headphones , 1 x microphone , 1 x audio line-out , 1 x LAN (Gigabit Ethernet) - RJ-45 , 1 x USB 3.1 (fast-charging) |
Miscellaneous | |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Power | |
Device Type | Power adapter |
Nominal Voltage | AC 120/230 V (50/60 Hz) |
Power Provided | 90 Watt |
Efficiency | 89% |
Power Factor Correction | Yes (active) |
Operating System / Software | |
OS Provided | Windows 10 Home 64-bit Edition English |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Dimensions & Weight | |
Width | 49.77 cm |
Depth | 5.8 cm |
Height | 34.7 cm |
Weight | 5.51 kg |
