HP Quick Relase Bracket for TFT
£35.01
Delivery:
Key features
  • A range of unique positioning options provide a comfortable working environment and maximum desktop space
  • Clean appearance for flat panel displays – ideal for storefronts, office reception areas, conferences and trade shows
  • Convenient assembly – a failsafe "Sure-Lock" connector enables you to snap your monitor or mounted device securely in place (Sure-Lock not included)
  • Medical/institutional settings: Securely mount monitors in nursing stations and public areas.
  • Training labs: Mount a monitor directly on a 100 mm VESA-compatible PC or HP Compaq t5720 Thin Client for all-in-one convenience.
Product codes
A secure and easy-to-use mounting solution for your VESA-compliant HP flat panel monitors, thin clients and other HP desktop products. Attach to any a compatible stand, bracket or wall mount and make the most of your workspace.
Product Description HP Quick Release - mounting kit
Product Type Mounting kit
Mounting Components Quick release bracket
Dimensions (WxDxH) 13.2 cm x 1.65 cm x 16 cm
Weight 370 g
Recommended Use LCD display / thin client
VESA Mounting Interface 100 x 100 mm
Max Load Weight 10.9 kg
Package Content 8 x 15.5 mm screws, 4 x 20 mm screws, 8 x 10 mm screws
Manufacturer Warranty 1-year warranty
Designed For HP 260 G2, Elite 8300, t430, t530, t5545, t628; Chromebox G2; EliteDesk 705 G3; EliteOne 800 G1, 800 G3, 800 G5; Flexible t520, t610; ProDesk 400 G3; ProOne 400 G2, 600 G1; RP9 G1 Retail System; Smart t410; Thin Client t5730; HPE t5145, t5540; Compaq Thin Client t5735; Flexible Thin Client t510
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP Quick Relase Bracke...
£35.01
