HP Quick Release Kit
£36.90
Delivery:
Key features
  • A range of unique positioning options provide a comfortable working environment and maximum desktop space
  • Clean appearance for flat panel displays – ideal for storefronts, office reception areas, conferences and trade shows
  • Convenient assembly – a failsafe "Sure-Lock" connector enables you to snap your monitor or mounted device securely in place (Sure-Lock not included)
  • Medical/institutional settings: Securely mount monitors in nursing stations and public areas.
  • Training labs: Mount a monitor directly on a 100 mm VESA-compatible PC or HP Compaq t5720 Thin Client for all-in-one convenience.
Product codes
A secure and easy-to-use mounting solution for your VESA-compliant HP thin clients, compatible HP flat panel monitors and other HP desktop products. Attach to any a compatible stand, bracket or wall mount and make the most of your workspace.
HP Quick Release - mounting kit
Mounting kit
13.2 cm x 1.7 cm x 16 cm
370 g
Recommended Use
Flat panel
Flat Panel Mount Interface
100 x 100 mm
Max Load Weight
10.9 kg
1 year warranty
HP 260 G2, 6300, Elite 8300, L2105, t430, t530, t5545, t628; Chromebox G2; EliteDesk 705 G3; EliteOne 800 G1, 800 G3; Flexible t520, t610; ProDesk 400 G3; ProOne 400 G2, 600 G1; Smart t410; Thin Client t5730; HPE t5145, t5540; Compaq Thin Client t5735; Flexible Thin Client t510
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
£36.90
