HP ScanJet Enterprise Flow 7000 s3 Sheet-feed Scanner - docum...
HP ScanJet Enterprise Flow 7000 s3 Sheet-feed Scanner - document scanner
£727.24
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Capture entire documents with one-pass duplex scanning up to 150 ipm black-and-white and colour.
  • Identify new devices and gain insight into scanning with HP Web Jetadmin remote discovery and monitoring.
  • Save time and simplify complex scan jobs with HP Smart Document Scan Software.
  • Type: Document scanner
  • Form Factor: Desktop
  • Max Paper Size: 216 x 3100 mm
  • Interface: USB 2.0, USB 3.0
  • Compatibility: PC
Product codes
Give the office high-volume scanning performance. Easily download software – including Kofax VRS 5.1 Professional – that helps you save time and capture confidently. Achieve scan speeds up to 75 ppm/150 ipm. Recommended for 7,500 pages per day.
Fast, smooth scanning – even unattended
Peak workflow performance. Smarter scanning.
Professional-grade scanning that helps save time
Product Description HP ScanJet Enterprise Flow 7000 s3 Sheet-feed Scanner - document scanner - desktop - USB 3.0, USB 2.0
Device Type Document scanner - desktop
Interface Type USB 3.0, USB 2.0
Additional Functions Email, fax
Max Supported Document Size 216 x 3100 mm
Localisation English, German, French, Italian, Spanish / Europe
Input Type Colour
Grayscale / Color Depth 48-bit colour
Optical Resolution 600 dpi x 600 dpi
Max Document Scan Speed 75 ppm (mono)
Max Document Size 216 mm x 3100 mm
Automatic Duplexing Yes
Document Feeder Type Automatic
Document Storage Capacity 80 sheets
Duty Cycle 7500 scans per day
Environmental Standards ENERGY STAR Qualified
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP ScanJet Enterprise...
£727.24
