HP Scanjet Enterprise Flow 7500 Flatbed Scanner
£1,024.52
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Get fast, reliable scanning – up to 50 ppm/100 ipm with 200 dpi in black-and-white, greyscale and colour.
  • Scan with confidence – HP EveryPage technology keeps scan projects running smoothly.
  • Simplify scanning tasks with HP Smart Document Scan Software and automatically enhance images for ideal scans.
  • Type: Document scanner
  • Form Factor: Desktop
  • Max Paper Size: 216 x 864 mm
  • Interface: USB 2.0
  • Compatibility: PC
Product codes
Easily integrate this legal flatbed scanner into document workflows. Get rapid scanning and reliable paper handling with HP EveryPage technology. Workgroups can enhance scans with a suite of comprehensive scan software.
Product Description HP ScanJet Enterprise Flow 7500 - document scanner - desktop - USB 2.0
Device Type Document scanner - desktop
Interface Type USB 2.0
Scan Element Type CCD
Light Source LED
Max Supported Document Size 216 x 864 mm
Localisation English, German, French, Italian, Spanish / Europe
Input Type Colour
Grayscale / Color Depth 8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution 600 dpi x 600 dpi
Max Document Scan Speed 50 ppm (mono) / 50 ppm (colour)
Max Document Size 216 mm x 864 mm
Automatic Duplexing Yes
Supported Document Type Plain paper, bulk objects (such as books, magazines and other bound materials), business card, plastic card, photo
Document Feeder Type Automatic
Document Storage Capacity 100 sheets
Duty Cycle 3000 scans per day
Power AC 120/230 V (50/60 Hz)
System Requirements Microsoft Windows XP Home Edition, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Windows 8
Microsoft Certification Compatible with Windows 7
Dimensions (WxDxH) 51.5 cm x 42.6 cm x 21.1 cm
Weight 10.61 kg
Environmental Standards ENERGY STAR Qualified
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been opened but is in excellent condition
Ref: 9HDG 040107
£958.04
product
Ref: 9HDG 040107
Accessories
Packaging
Functional
Software
Manuals
£958.04
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP Scanjet Enterprise...
£1,024.52
