HP Scanjet Pro 2000 s1 Sheet-feed Scanner - document scanner
£316.90
Delivery:
Standard: 1-3 working days
Key features
  • Define scan profiles for common document types, and scan to multiple destinations with HP Scan software.
  • Produce scans at up to 24 ppm/48 ipm with two-sided scanning that captures both sides at once.
  • Streamline routine work with one-touch scanning – create one-button, custom settings for recurring scan jobs.
  • Type: Document scanner
  • Form Factor: Desktop
  • Max Paper Size: 216 x 3100 mm
  • Interface: USB 2.0
  • Compatibility: Mac, PC
Product codes
Fast, affordable, and designed to handle everything from simple colour jobs to complex workflows. Quickly and reliably digitise larger projects with scan speeds up to 24 ppm/48 ipm and a 50-page ADF. Recommended for 2,000 pages per day.
Small size. Fast scans. Same reliable results.
Optimise workflows with one-touch scanning
Capture business documents like a pro
Product Description HP Scanjet Pro 2000 s1 Sheet-feed - document scanner - desktop - USB 2.0
Device Type Document scanner - desktop
Interface Type USB 2.0
Max Supported Document Size 216 x 3100 mm
Localisation English, German, French, Italian, Spanish / Europe
Input Type Colour
Grayscale / Color Depth 48-bit colour
Optical Resolution 600 dpi x 600 dpi
Max Document Scan Speed 24 ppm (mono)
Max Document Size 216 mm x 3100 mm
Automatic Duplexing Yes
Document Feeder Type Automatic
Document Storage Capacity 50 sheets
Duty Cycle 2000 scans per day
Environmental Standards ENERGY STAR Qualified
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP Scanjet Pro 2000 s1...
£316.90
