HP Scanjet Pro 2500 f1 Document Scanner
£281.24
Delivery:
Standard: 1-3 working days
Key features
  • Accurately capture text from documents for easy editing with HP Scan and I.R.I.S. Readiris™ Pro OCR software.
  • Produce up to 40 images per minute with two-sided scanning and a 50-page automatic document feeder.
  • Streamline routine work with one-touch scanning – create one-button, custom settings for recurring scan jobs.
  • Type: Document scanner
  • Form Factor: Desktop
  • Max Paper Size: 216 x 3100 mm
  • Interface: USB 2.0
  • Compatibility: Mac, PC
Product codes
Enhance productivity for routine scanning with a compact HP ScanJet Pro. Automate workflow with fast, two-sided scanning, a 50-page ADF, 1,500-page daily duty cycle, and one-button shortcuts. You can even quickly capture and edit text from documents.
Product Description HP Scanjet Pro 2500 f1 - document scanner - desktop - USB 2.0
Device Type Document scanner - desktop
Interface Type USB 2.0
Scan Element Type CMOS / CIS
Light Source LED
Max Supported Document Size 216 x 3100 mm
Localisation English, German, French, Italian, Spanish / Europe
Input Type Colour
Grayscale / Color Depth 8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution 1200 dpi x 1200 dpi
Max Document Scan Speed 20 ppm (mono) / 20 ppm (colour)
Max Document Size 216 mm x 3100 mm
Automatic Duplexing Yes
Document Feeder Type Automatic
Document Storage Capacity 50 sheets
Duty Cycle 1500 scans per day
Power AC 120/230 V (50/60 Hz)
System Requirements Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Windows 8.1 (32/64 bits), Apple MacOS X 10.9, Apple MacOS X 10.10, Windows 10 (32/64 bits)
Microsoft Certification Compatible with Windows 7
Dimensions (WxDxH) 45.1 cm x 35.1 cm x 12.2 cm
Weight 4.3 kg
Environmental Standards ENERGY STAR Qualified
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP Scanjet Pro 2500 f1...
£281.24
