General |
Type |
Document scanner - desktop |
Interface Type |
USB 3.0 |
Max Supported Document Size |
216 x 3100 mm |
Localisation |
English, German, French, Italian, Spanish / Europe |
Scanner |
Input Type |
Colour |
Grayscale Depth |
8-bit (256 grey levels) |
Colour Depth |
24-bit (16.7 million colours) |
Optical Resolution |
1200 dpi x 1200 dpi |
Scan Mode |
Single-pass |
Automatic Duplexing |
Yes |
Scan Element Type |
CMOS / CIS |
Bulb / Light Source Type |
LED |
Max Document Scan Speed B/W |
25 ppm |
Max Document Scan Speed Colour |
25 ppm |
Control Panel Buttons Functions |
Scan, cancel, duplex, tools |
Duty Cycle |
3000 scans per day |
Scanner Speed Details |
25 ppm - 300 dpi , 50 ipm - duplex - 300 dpi (front) / 300 dpi (back) |
Scanner Features |
Built-in LCD screen |
Compliant Standards |
TWAIN, WIA |
Media Handling |
Max Document Size |
216 mm x 3100 mm |
Supported Document Type |
Plain paper, plastic card, labels, photo, envelope |
Supported Document Size Details |
ADF - up to 216 x 3100 mm , Flatbed - up to 216 x 297 mm |
Document Feeder Type |
Automatic |
Document Storage Capacity |
50 sheets |
Expansion / Connectivity |
Interfaces |
USB 3.0 |
Miscellaneous |
Cables Included |
1 x USB cable |
Compatible with Windows 7 |
"Compatible with Windows 7" software and devices carry Microsoft’s assurance that these products have passed tests for compatibility and reliability with 32-bit and 64-bit Windows 7. |
C-Tick, BSMI, CISPR 24, cUL, EN 61000-3-2, EN55022, ICES-003, SASO, EN 61000-3-3, CISPR 22, CCC, EMC, RoHS, IEC 60950-1, EN 60950-1, UL 60950-1 Second Edition, KCC, BSMI CNS 13438, FCC CFR47 Part 15 B, CSA C22.2 No. 60950-1 Second Edition, KN22, EAC, TER, PVOC, CoC |
Environmental Standards |
ENERGY STAR Certified |
Yes |
Power |
Power Device |
External power adapter |
Voltage Required |
AC 120/230 V (50/60 Hz) |
Power Consumption Stand by |
4.51 Watt |
Power Consumption Sleep |
1.4 Watt |
Software / System Requirements |
Software Included |
Readiris Pro, Cardiris, Nuance PaperPort, HP Scan, HP Scanner Tools Utility |
OS Required |
Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Windows 8.1 (32/64 bits), Apple MacOS X 10.9, Apple MacOS X 10.10, Windows 10 (32/64 bits) |
System Requirements Details |
Windows 7/8/8.1/10 - 2 GHz - RAM 2 GB - HD 170 MB , MacOS X 10.9/10.10 - RAM 1 GB |
Dimensions & Weight |
Width |
46 cm |
Depth |
38.7 cm |
Height |
14.5 cm |
Weight |
5.58 kg |
Dimensions & Weight (Shipping) |
Shipping Width |
57.9 cm |
Shipping Depth |
49.9 cm |
Shipping Height |
24.5 cm |
Shipping Weight |
7.6 kg |
Manufacturer Warranty |
Service & Support |
Limited warranty - 1 year |
Environmental Parameters |
Min Operating Temperature |
10 °C |
Max Operating Temperature |
35 °C |
Humidity Range Operating |
15 - 80% (non-condensing) |
