HP ScanJet Pro 3500 f1 Document Scanner
£369.32
17 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Accurately capture text from documents for easy editing with HP Scan and I.R.I.S. Readiris™ Pro OCR software.
  • Define scan profiles for common document types and scan to multiple destinations with HP Scan software.
  • Produce up to 50 images (25 pages) per minute with two-sided scanning. Reliably scan 3,000 sheets per day.
  • Type: Document scanner
  • Form Factor: Desktop
  • Max Paper Size: 216 x 3100 mm
  • Interface: USB 3.0
  • Compatibility: Mac, PC
Product codes
Get reliable, high-speed scanning for complex projects – this scanner can handle 3,000 sheets per day. Scan both sides of the page at up to 50 images (25 pages) per minute. HP EveryPage helps avoid misfeeds and simplifies your workflow.
Product Description HP Scanjet Pro 3500 f1 - document scanner - desktop - USB 3.0
Device Type Document scanner - desktop
Interface Type USB 3.0
Scanning Sensor Type CMOS / CIS
Light Source LED
Max Supported Document Size 216 x 3100 mm
Localisation English, German, French, Italian, Spanish / Europe
Input Type Colour
Grayscale / Color Depth 8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution 1200 dpi x 1200 dpi
Max Document Scan Speed 25 ppm (mono) / 25 ppm (colour)
Max Document Size 216 mm x 3100 mm
Automatic Duplexing Yes
Supported Document Type Plain paper, plastic card, labels, photo, envelope
Document Feeder Type Automatic
Document Storage Capacity 50 sheets
Duty Cycle 3000 scans per day
Power AC 120/230 V (50/60 Hz)
System Requirements Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Windows 8.1 (32/64 bits), Apple MacOS X 10.9, Apple MacOS X 10.10, Windows 10 (32/64 bits)
Microsoft Certification Compatible with Windows 7
Dimensions (WxDxH) 46 cm x 38.7 cm x 14.5 cm
Weight 5.58 kg
Environmental Standards ENERGY STAR Qualified
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP ScanJet Pro 3500 f1...
£369.32
