HP ScanJet Pro 4500 fn1 Document Scanner
£638.62
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Produce up to 60 images (30 pages) per minute with two-sided scanning – recommended for 4,000 sheets per day.
  • Scan images directly into applications with included and full-featured Kofax VRS Pro®, TWAIN, and ISIS®.
  • Send scans right from the scanner to email, network folders, or a PC via a gigabit Ethernet connection.
  • Type: Document scanner
  • Form Factor: Desktop
  • Max Paper Size: 216 x 3100 mm
  • Interface: Gigabit LAN, USB 3.0, Wi-Fi(n)
  • Compatibility: Mac, PC
Product codes
Get fast two-sided scanning with a network scanner recommended for 4,000 sheets per day. Digital sending is easy from the touchscreen via wireless network or Wi-Fi Direct. Send scans to mobile devices using the HP JetAdvantage Capture app.
Product Description HP Scanjet Pro 4500 fn1 - document scanner - desktop - USB 3.0, Gigabit LAN, Wi-Fi(n)
Device Type Document scanner - desktop
Interface Type USB 3.0, Gigabit LAN, Wi-Fi(n)
Scan Element Type CMOS / CIS
Light Source LED
Additional Functions Email, scan to cloud
Max Supported Document Size 216 x 3100 mm
Localisation English, German, French, Italian, Spanish / Europe
Input Type Colour
Grayscale / Color Depth 8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution 1200 dpi x 1200 dpi
Max Document Scan Speed 30 ppm (mono) / 30 ppm (colour)
Max Document Size 216 mm x 3100 mm
Automatic Duplexing Yes
Supported Document Type Business card, labels, photo, envelope, post card
Document Feeder Type Automatic
Document Storage Capacity 50 sheets
Duty Cycle 4000 scans per day
Power AC 120/230 V (50/60 Hz)
System Requirements Microsoft Windows 7 or later, Apple MacOS X 10.11
Dimensions (WxDxH) 52 cm x 38.7 cm x 14.5 cm
Weight 5.98 kg
Environmental Standards ENERGY STAR Qualified
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP ScanJet Pro 4500 fn...
£638.62
