HP SINGLE MONITOR ARM
£130.48
10 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Flexible arm adjusts to your size, posture and work preference
  • Locate the arm wherever it is most convenient for you on a desk, and secure then it with the adjustable clamp
  • Space saving design frees up valuable desk space
  • Supports up to one 27 inch (68.58 cm) diagonal display
  • Accessory Type: Bracket
  • Stock Status: In Stock
Product codes
The HP Single Monitor Arm is the perfect desk accessory for your work life. Sleek and streamlined, the HP Single Monitor Arm is designed to complement the way you work.
Product Description HP Single Monitor Arm - mounting kit
Product Type Mounting kit
Mounting Components Desk clamp mount, grommet mount, single-screen mounting arm
Adjustments Tilt
Recommended Use LCD display
Recommended Display Size Up to 24"
VESA Mounting Interface 100 x 100 mm, 75 x 75 mm
Max Load Weight 9.1 kg
Colour Jack black
Designed For HP 100, 6300, Elite 8300, L2105, LA1751, LA1905, LA1951, LA2006, LA22, LA2206, LA2306, LE1711, LE19, LE1901, LE1911, LE2001, t430, ZR22, ZR24; EliteDesk 705 G3, 705 G4; EliteOne 705 G2, 800 G1, 800 G2, 800 G3, 800 G5; ProDesk 400 G3, 600 G4; ProOne 400 G2, 400 G3, 400 G4, 600 G1, 600 G2, 600 G3
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
£130.48
