HP Slice ODD Module
HP Slice ODD Module
£96.00
Delivery:
Key features
  • Create a unique solution for each of your employees when you use the HP ODD Module stacked with your HP Elite Slice and any of the other HP Elite Slice accessories.
  • Securing your solution is simpler than ever with an integrated universal lock slot that allows you to lock your Module and HP Elite Slice together with one cable lock.
  • Snap the Module beneath your HP Elite Slice with a sturdy USB-type connection that provides a simple and clean solution with no messy cables.
  • Support legacy content on CD or DVDs, or use this module with the HP Audio Module as a beautiful media player.
Product codes
Hardware compatibility
HP Elite Slice and HP Elite Slice for Meeting Rooms
Quickly and easily back up files and access content from your choice of optical media with the HP ODD Module that snaps into your HP Elite Slice solution for a simple unified footprint.
No cabling or screws required
Multi ODD media compatible
Lock it down
Mix and match
Product Description HP ODD Module - DVD-ROM drive - external
Device Type DVD-ROM drive - external
Dimensions (WxDxH) 16.5 cm x 16.5 cm x 2.45 cm
Weight 452 g
Optical Storage DVD-ROM
Manufacturer Warranty 1-year warranty
Designed For OMEN X by HP 900; HP 20, 22, 24, 24 g008; Elite Slice, Slice for Meeting Rooms, Slice for Meeting Rooms G2, Slice G2; ENVY 750; ENVY Curved 34; Pavilion 24, 27; Pavilion Wave 600
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP Slice ODD Module
£96.00
