Mount your HP Elite Slice, Cover, and Modules to a fixed location on a desk or table with the HP VESA Plate, which allows them to be stacked and anchored with the 100 x 100 VESA pattern.
Assemble and disassemble the HP VESA Plate from your configuration with the easy Quick Release latch.
Securing your solution is simpler than ever with an integrated universal lock slot that allows you to lock your HP Elite Slice and HP VESA Plate together with one cable lock.
Use the HP VESA Plate with a stacked configuration of an HP Elite Slice and HP Wireless Charging or HP Collaboration Cover, HP Audio Module, and HP ODD Module.
HP Elite Slice and HP Elite Slice for Meeting Rooms
