HP SpacePilot Pro USB 3D Input Device
Key features
  • 3D motion controller cap – With six degrees of freedom sensing technology, move intuitively in a single axis or in multiple axes at the same time simply by pushing, pulling, twisting, and/or tilting the control cap. This is especially valuable when working with multiple 3D enabled applications because the SpacePilot Pro standardizes the control of 3D objects; you no longer need to remember each application's unique control key sequence for 3D movement.
  • Color LCD Workflow Assistant Display – The full-color LCD delivers at-a-glance visibility of e-mail, tasks, calendar entries and function key commands ensuring quick access to key information without interrupting your workflow
  • QuickView Navigation Keys – provide fingertip access to 32 standard views giving an unparalleled level of control that encourages model exploration leading to improved error detection and design quality.
Product codes
Working in 3D has just become easier and more efficient with an HP SpacePilot Intelligent Controller, which combines refined sensing technology, extendable speed keys, and ergonomic design to give you 3D control, speeding up your design work -faster than you ever thought possible. When you intuitively push, tilt, or twist the control cap, the response is immediate. SpacePilot also features 21 speed keys that increase your efficiency and make working with your designs less stressful and more enjoyable, without the intrusive functionality of a mouse and keyboard alone.
HP SpacePilot USB 3D Intelligent Controller - 3D motion controller - USB
Wired - USB
15 cm x 23.1 cm x 5.8 cm
0.9 kg
Buttons Qty
21
LCD screen
Workstation Z230, Z420, Z820
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP SpacePilot Pro USB...
