HP t420 Thin client 2GB RAM 8GB
Key features
  • Get essential OS and HP software plus support for VoIP with Microsoft Lync Unified Communications tools.
  • Plan ahead with a reliable solid-state, fan-less design, Global Series availability, two-year lifecycle, and three-year limited warranty.
  • Tailor your installation with your OS of choice, and enjoy simple setup, deployment, and maintenance with integrated HP software tools.
  • The modern 0.88 liter form factor fits into a range of compact work spaces and attaches to any flat surface or an HP ProDisplay.
Product codes
Do more with the HP t420 Thin Client, an affordable cloud computing solution that delivers trustworthy reliability and easy deployment and use.
More Bang For Your Buck
Get your choice of essential operating systems, support for VoIP with Microsoft Lync Unified Communications tools, and value-added integrated software from HP that helps you deploy, manage, and optimize your new systems.
Solid Reliability
Plan ahead with reliable flash memory storage and a fan-less design for ultra-quiet deployments. Choose a Global Series model and custom image to help ensure worldwide consistency. Rest easy with a two-year lifecycle and three-year limited warranty.
Place It Where You Need It
Install throughout your business-the modern 0.88 liter form factor complements and fits into a range of compact work spaces, and the integrated VESA mount enables mounting on a flat surface, or directly behind an HP ProDisplay.
Easy Customization
Tailor your installation with the OS of your choice-HP Thin Pro, HP Smart Zero, or Windows Embedded Standard 7E. Enjoy simplified setup, deployment, and maintenance with HP Device Manager, a software tool available exclusively for HP Thin Clients.
HP t420 - compact desktop - GX-209JA 1 GHz - 2 GB - 8 GB - UK layout
Thin client - compact desktop
1 x AMD GX-209JA 1 GHz (Dual-Core)
RAM
2 GB (installed) / 2 GB (max) - DDR3L SDRAM
Hard Drive
1 x flash 8 GB
Optical Storage
No optical drive
GigE
OS Provided
HP ThinPro 32-bit
18 cm x 14 cm x 3.5 cm
740 g
Pricing Type
Promo
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP t420 Thin client 2G...
