HP T530 AMD Radeon GX-215JJ 4GB 32GB Windows 10 Thin Client
£504.74
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Packed with flash storage, memory and connectivity options, along with multiple ports including USB-C™ to support both old and new peripherals, your transition into the future will be seamless.
  • The newest AMD thin client technology perfects performance and efficiency, delivering an amazing PC-like experience in the cloud.
  • With a modern, new look and a small size, the HP t530 has raised the stakes for thin client design. Multiple deployment options allow this thin client to fit into any workspace.
  • Processor Type: GX-215JJ
  • Operating System: Windows 10 IoT Enterprise
  • Installed Memory: 4GB
  • Hard Drive Capacity: 32GB
  • Storage Type: Flash
Product codes
Upgrade your cloud computing environment with the first HP thin client made for the office of the future. Elegantly designed with essential performance and reliability, the HP t530 Thin Client meets the needs of today and the growing demands of tomorrow.
Product Description HP t530 - tower - GX-215JJ 1.5 GHz - 4 GB - 32 GB
Type Thin client - tower
Localisation Language: English / region: United Kingdom
Processor 1 x AMD GX-215JJ 1.5 GHz (2 GHz) (Dual-Core)
Processor Main Features AMD Turbo CORE Technology
Cache Memory 1 MB L2 Cache
Cache Per Processor 1 MB
RAM 4 GB (installed) / 16 GB (max) - DDR4 SDRAM - non-ECC - PC4-14900
Hard Drive 1 x flash 32 GB - M.2
Optical Storage No optical drive
Graphics Controller AMD Radeon R2E
Networking GigE
Power AC 120/230 V (50/60 Hz)
OS Provided Windows 10 IoT Enterprise
Dimensions (WxDxH) 3.5 cm x 20 cm x 20 cm
Weight 962.8 g
Environmental Standards ENERGY STAR Qualified
Manufacturer Warranty Limited warranty - parts and labour - 3 years
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP T530 AMD Radeon GX-...
£504.74
