Upgrade your cloud computing environment with the first HP thin client made for the office of the future. Elegantly designed with essential performance and reliability, the HP t530 Thin Client meets the needs of today and the growing demands of tomorrow.
Product Description | HP t530 - tower - GX-215JJ 1.5 GHz - 4 GB - 8 GB | Type | Thin client - tower | Localisation | Language: English / region: United Kingdom | Processor | 1 x AMD GX-215JJ 1.5 GHz (2 GHz) (Dual-Core) | Processor Main Features | AMD Turbo CORE Technology | Cache Memory | 1 MB L2 Cache | Cache Per Processor | 1 MB | RAM | 4 GB (installed) / 16 GB (max) - DDR4 SDRAM - non-ECC - PC4-14900 | Hard Drive | 1 x flash 8 GB - M.2 | Optical Storage | No optical drive | Graphics Controller | AMD Radeon R2E | Networking | GigE | Power | AC 120/230 V (50/60 Hz) | OS Provided | HP ThinPro | Dimensions (WxDxH) | 3.5 cm x 20 cm x 20 cm | Weight | 962.8 g | Manufacturer Warranty | Limited warranty - parts and labour - 3 years |
General | |
Type | Thin client |
Product Form Factor | Tower |
Embedded Security | Trusted Platform Module (TPM 2.0) Security Chip |
Processor / Chipset | |
CPU | AMD GX-215JJ 1.5 GHz |
Max Turbo Speed | 2 GHz |
Number of Cores | Dual-Core |
CPU Qty | 1 |
Max CPU Qty | 1 |
CPU Upgradability | Not upgradable |
Cache Memory | |
Installed Size | L2 Cache - 1 MB |
RAM | |
Installed Size | 4 GB / 16 GB (max) |
Technology | DDR4 SDRAM - non-ECC |
Effective Memory Speed | 1866 MHz |
Rated Memory Speed | 1866 MHz |
Memory Specification Compliance | PC4-14900 |
Form Factor | SO-DIMM 260-pin |
Slots | 1 (Total) / 0 (empty) |
Features | Unbuffered |
Configuration Features | 1 x 4 GB |
Hard Drive | |
Type | Flash - M.2 |
Capacity | 1 x 8 GB |
Optical Storage | |
Type | No optical drive |
Monitor | |
Monitor Type | None. |
Graphics Controller | |
Graphics Processor | AMD Radeon R2E |
Video Interfaces | DisplayPort |
Max Monitors Supported | 2 |
Networking | |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet |
Features | Wake on LAN (WoL), DHCP support, PXE support |
Compliant Standards | IEEE 802.1x |
Expansion / Connectivity | |
Slots | 1 (total) / 0 (free) x M.2 Card |
Interfaces | 3 x USB 3.1 Gen 1 (1 front, 2 rear) , 1 x USB-C 3.1 Gen 1 (1 in front) , 2 x USB 2.0 (2 rear) , Headphones/microphone (1 in front) , 2 x DisplayPort , 1 x LAN (Gigabit Ethernet) - RJ-45 |
Miscellaneous | |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Compliant Standards | UL, VCCI, GS, CB, CCC, FCC, RoHS, KCC, WEEE, CISPR, ICES, MEPS, ERP, CECP, EMI, low halogen |
Power | |
Device Type | Power adapter |
Nominal Voltage | AC 120/230 V (50/60 Hz) |
Power Provided | 45 Watt |
Operating System / Software | |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 3 years |
Dimensions & Weight | |
Width | 3.5 cm |
Depth | 20 cm |
Height | 20 cm |
Weight | 962.8 g |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
