General |
Type |
Thin client |
Product Form Factor |
Tower |
Embedded Security |
Trusted Platform Module (TPM 1.2) Security Chip |
Localisation |
Language: English / region: United Kingdom |
Processor / Chipset |
CPU |
AMD GX-420GI 2 GHz |
Max Turbo Speed |
2.2 GHz |
Number of Cores |
Quad-Core |
CPU Qty |
1 |
Max CPU Qty |
1 |
CPU Upgradability |
Not upgradable |
Processor Main Features |
AMD Turbo CORE Technology |
Cache Memory |
Installed Size |
L2 Cache - 2 MB |
Cache Per Processor |
2 MB |
RAM |
Installed Size |
4 GB / 32 GB (max) |
Technology |
DDR4 SDRAM - non-ECC |
Effective Memory Speed |
1866 MHz |
Rated Memory Speed |
1866 MHz |
Memory Specification Compliance |
PC4-14900 |
Form Factor |
SO-DIMM 260-pin |
Slots |
2 (Total) / 1 (empty) |
Features |
Unbuffered |
Configuration Features |
1 x 4 GB |
Hard Drive |
Type |
Flash - M.2 |
Capacity |
1 x 8 GB |
Optical Storage |
Type |
No optical drive |
Monitor |
Monitor Type |
None. |
Graphics Controller |
Graphics Processor |
AMD Radeon R7E |
Video Interfaces |
VGA, DisplayPort |
Max Monitors Supported |
2 |
Networking |
Data Link Protocol |
Ethernet, Fast Ethernet, Gigabit Ethernet |
Features |
Wake on LAN (WoL), PXE support |
Expansion / Connectivity |
Slots |
1 (total) / 0 (free) x M.2 Card - 2280 , 1 (total) / 1 (free) x M.2 Card - 2242 |
Interfaces |
4 x USB 2.0 (2 front, 2 rear) , 3 x USB 3.0 (2 front, 1 internal) , 2 x DisplayPort , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) , 1 x serial , 1 x headphones/microphone (1 in front) , 1 x audio line-out/line-in , 1 x VGA |
Miscellaneous |
Theft/Intrusion Protection |
Security lock slot (cable lock sold separately) |
Security Slot Type |
Kensington security slot |
Compliant Standards |
FCC Class B certified, UL, GS, CB, CCC, RoHS, ICES Class B, MEPS, KCC Class B, ERP, CECP, VCCI Class B, CISPR Class B |
TAA Compliant |
Yes |
Power |
Device Type |
Power adapter |
Nominal Voltage |
AC 120/230 V (50/60 Hz) |
Power Provided |
65 Watt |
Operating System / Software |
OS Provided |
HP ThinPro |
Environmental Standards |
ENERGY STAR Certified |
Yes |
Manufacturer Warranty |
Service & Support |
Limited warranty - parts and labour - 3 years |
Dimensions & Weight |
Width |
12 cm |
Depth |
22 cm |
Height |
25.1 cm |
Weight |
1.52 kg |
Dimensions & Weight (Shipping) |
Shipping Weight |
4.1 kg |
Environmental Parameters |
Min Operating Temperature |
10 °C |
Max Operating Temperature |
40 °C |
Humidity Range Operating |
10 - 90% (non-condensing) |
