HP t610 PLUS Flexible Thin Client Dual-Core T56N 4GB
Key features
  • AMD’s APU technology, combining dual core processors with AMD HD 6320 graphics. Features DirectX 11 graphics support, DDR3-1600 RAM with up to 4 GB of capacity and AMD A55E Chipset with DVI-I and DisplayPort outputs.
  • Easy setup, easy manageability and easy maintenance. With HP t610 PLUS Flexible Thin Client, you can select from a range of HP Care Pack Services for support beyond standard.
  • Featuring HP Velocity and HP Thermal Protection. Eliminate network noise while maintaining high-quality performance, and guard against data loss induced by overheating.
  • Preloaded with HP’s TPM Chip built-in security feature, NIST-certified BIOS support, optional dual WiFi internal antennas, cable lock slot and power cord retention slot to prevent accidental power-off.
  • The HP t610 PLUS Flexible Thin Client features 6 USB ports: 2 USB 3.0 ports, 4 USB 2.0 ports, and PS/2 legacy ports, as well as 2 serial and 1 parallel ports. Use the standard Gigabit Ethernet or built-in WiFi option with dual, internal antennas (WiFi depending on model).
  • The HP t610 PLUS Flexible Thin Client is built with the environment in mind, including BFR/PVC-Free and post-Consumer Recycled Plastics > 20% (excluding PCB), ENERGY STAR® qualified, EPEAT® Gold registered.
Product codes
HP t610 Flexible Thin Client delivers added security, broad expansion options and a PC-like multimedia experience for virtualized desktops. A flexible solution with a powerful boost in performance.
HP Flexible t610 PLUS - tower - G-T56N 1.65 GHz - 4 GB - 16 GB
Thin client - tower
1 x AMD G-T56N 1.65 GHz (Dual-Core)
Cache Memory
1 MB L2 Cache
Cache Per Processor
1 MB
RAM
4 GB (installed) / 4 GB (max) - DDR3 SDRAM
Hard Drive
Flash 16 GB
Optical Storage
No optical drive
Graphics Controller
AMD Radeon HD 6320
Audio Output
Stereo - integrated
GigE
OS Provided
Microsoft Windows Embedded Standard 7P
6.5 cm x 22 cm x 24 cm
1.98 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Limited warranty - 3 years
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP t610 PLUS Flexible...
