General |
Type |
Thin client |
Recommended Use |
Small business, corporate business |
Product Form Factor |
Tower |
Built-in Devices |
Speaker |
Localisation |
Language: English / region: United Kingdom |
Processor / Chipset |
CPU |
AMD GX-217GA 1.65 GHz |
Number of Cores |
Dual-Core |
CPU Qty |
1 |
Max CPU Qty |
1 |
CPU Upgradability |
Not upgradable |
Cache Memory |
Installed Size |
L2 Cache - 1 MB |
Cache Per Processor |
1 MB |
RAM |
Installed Size |
4 GB / 16 GB (max) |
Technology |
DDR3L SDRAM |
Effective Memory Speed |
1600 MHz |
Rated Memory Speed |
1600 MHz |
Memory Specification Compliance |
PC3-12800 |
Form Factor |
SO-DIMM 204-pin |
Slots |
2 (Total) / 1 (empty) |
Features |
Low-voltage |
Configuration Features |
1 x 4 GB |
Hard Drive |
Type |
SSD - mSATA |
Capacity |
1 x 16 GB |
Interface Type |
SATA |
Features |
Multi-level cell (MLC) |
Optical Storage |
Type |
No optical drive |
Monitor |
Monitor Type |
None. |
Graphics Controller |
Type |
Integrated |
Graphics Processor |
AMD Radeon HD 8280E |
Video Interfaces |
VGA, DisplayPort |
Audio Output |
Type |
Integrated |
Sound Output Mode |
Stereo |
Max Sampling Rate |
192 kHz |
Input Device |
Type |
Mouse, keyboard |
Keyboard |
Interface |
USB |
Mouse |
Technology |
Optical |
Interface |
USB |
Networking |
Type |
Integrated |
Data Link Protocol |
Ethernet, Fast Ethernet, Gigabit Ethernet |
Features |
Wake on LAN (WoL), DHCP support, PXE support |
Expansion / Connectivity |
Slots |
1 (total) / 0 (free) x mSATA , 2 (total) / 1 (free) x SO-DIMM 204-pin , 1 (total) / 1 (free) x PCIe Mini Card , 1 (total) / 1 (free) x M.2 Card |
Interfaces |
6 x USB 2.0 (2 front, 2 rear) , 2 x USB 3.0 (2 in front) , 2 x DisplayPort , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 1 x audio line-in , 1 x audio line-out , 1 x VGA |
Miscellaneous |
Theft/Intrusion Protection |
Security lock slot (cable lock sold separately) |
Security Slot Type |
Kensington security slot |
Compliant Standards |
FCC Class B certified, TUV GS, VCCI, UL 1950, CSA 22.2 No. 950, EN55022 Class B, RoHS, WEEE |
TAA Compliant |
Yes |
Power |
Device Type |
Power adapter |
Nominal Voltage |
AC 120/230 V (50/60 Hz) |
Power Provided |
65 Watt |
Operating System / Software |
OS Provided |
Windows Embedded 8 Standard x64 Edition |
OS Certified |
Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Citrix Presentation Server 4.0, Citrix XenDesktop 3.0, Citrix XenApp 5, Microsoft Windows Server 2012 |
Environmental Standards |
ENERGY STAR Certified |
Yes |
Manufacturer Warranty |
Service & Support |
Limited warranty - parts and labour - 3 years |
Dimensions & Weight |
Width |
4 cm |
Depth |
22 cm |
Height |
24 cm |
Weight |
1.36 kg |
Environmental Parameters |
Min Operating Temperature |
10 °C |
Max Operating Temperature |
40 °C |
Humidity Range Operating |
10 - 90% (non-condensing) |
