HP t620 Flexible Thin Client AMD GX-415GA 4GB 16GB Windows Em...
HP t620 Flexible Thin Client AMD GX-415GA 4GB 16GB Windows Embedded Standard 7P 64-bit
£574.70
Delivery:
Key features
  • Configure your deployment to provide a powerful seamless desktop experience for your end users without exceeding your budget.
  • Customize your thin client with everything you need and nothing you don’t. Choose the configuration options and expansion capabilities that best fit your business and help ensure an ideal end user experience.
  • Help protect your thin client environment with integrated and optional hardware and software security solutions, including: HP BIOS implemented to NIST guidelines, a TPM chipset, Fiber NIC communications, and lockable covers and ports.
  • Reduce desktop service calls and product refreshes with a completely redesigned chassis that includes advanced passive cooling for fan-less support of quad-core processors.
Product codes
Get a powerful and seamless desktop experience, enhanced security features, and premium client virtualization from the HP t620 Flexible Series Thin Client.
Product Description HP Flexible t620 - tower - GX-415GA 1.5 GHz - 4 GB - SSD 16 GB
Type Thin client - tower
Localisation Language: English / region: United Kingdom
Processor 1 x AMD GX-415GA 1.5 GHz (Quad-Core)
Cache Memory 2 MB L2 Cache
Cache Per Processor 2 MB
RAM 4 GB (installed) / 16 GB (max) - DDR3L SDRAM - PC3-12800
Hard Drive SSD 16 GB - SATA - mSATA
Optical Storage No optical drive
Graphics Controller AMD Radeon HD 8330E
Audio Output Stereo - integrated
Networking GigE
Power AC 120/230 V (50/60 Hz)
OS Provided Microsoft Windows Embedded Standard 7P 64-bit
Dimensions (WxDxH) 4 cm x 22 cm x 24 cm
Weight 1.36 kg
Environmental Standards ENERGY STAR Qualified EPEAT Gold
Manufacturer Warranty Limited warranty - parts and labour - 3 years
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP t620 Flexible Thin...
£574.70
