HP t630 - Thin client - tower - 1 x GX-420GI 2 GHz
£451.04
Delivery:
Key features
  • Configure a precise deployment with legacy ports for reliable peripherals, DDR4 system memory, wired or optional wireless or fiber connectivity and optional local dual flash memory up to 128 GB.
  • Speed performance with an expertly-engineered thin client driven by an embedded x86 quad-core system-on-a-chip with integrated AMD Radeon graphics for up to two UHD/4K displays.
  • Tailor your OS environment, remotely set up and deploy, boost Wi-Fi and network performance, and get local-quality multimedia on the cloud with HP’s exclusive value-added thin client software.
Product codes
Optimize your cloud-based deployments with the powerful, highly configurable, and long lifecycle HP t630 Thin Client. Support your business now and in the future with quad-core processing, dual UHD/4K display compatibility, and options for device and network connectivity and local storage.
Designed to go above and beyond
Speed performance with an expertly engineered thin client driven by an embedded x86 quad-core system-on-a-chip. The integrated AMD Radeon graphics engine supports up to two UHD/4K displays for a fantastic media experience.
Bridge the gap with expansive connectivity
Configure a precise deployment with legacy ports for your reliable peripherals, dual-channel DDR4 system memory, wired or optional wireless or fiber connectivity, and optional local dual flash memory up to 128 GB for separate, discrete storage.
Software with all the extras, minus the extra cost
Tailor your OS environment, remotely set up and deploy, boost Wi-Fi and network performance, and get local-quality multimedia on the cloud with exclusive HP value-added software: HP Device Manager, HP Velocity, HP True Graphics, and HP Easy Shell.
HP t630 - tower - GX-420GI 2 GHz - 4 GB - 8 GB
Thin client - tower
1 x AMD GX-420GI 2 GHz (2.2 GHz) (Quad-Core)
Processor Main Features
AMD Turbo CORE Technology
Cache Memory
2 MB L2 Cache
Cache Per Processor
2 MB
RAM
4 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC - PC4-17000
Hard Drive
1 x flash 8 GB - M.2
Optical Storage
No optical drive
Graphics Controller
AMD Radeon R6E
GigE
OS Provided
HP Smart Zero Core 32-bit
12 cm x 22 cm x 25.1 cm
1.52 kg
Pricing Type
Promo
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP t630 - Thin client...
£451.04
