HP T630 AMD Radeon GX-420GI 4GB 8GB Thin Client
£298.86
22 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Configure a precise deployment with legacy ports for reliable peripherals, DDR4 system memory, wired or optional wireless or fiber connectivity and optional local dual flash memory up to 128 GB.
  • Speed performance with an expertly-engineered thin client driven by an embedded x86 quad-core system-on-a-chip with integrated AMD Radeon graphics for up to two UHD/4K displays.
  • Tailor your OS environment, remotely set up and deploy, boost Wi-Fi and network performance, and get local-quality multimedia on the cloud with HP’s exclusive value-added thin client software.
  • Processor Type: GX-420GI
  • Operating System: HP Smart Zero Core
  • Installed Memory: 4GB
  • Hard Drive Capacity: 8GB
  • Storage Type: Flash
Product codes
Optimize your cloud-based deployments with the powerful, highly configurable, and long lifecycle HP t630 Thin Client. Support your business now and in the future with quad-core processing, dual UHD/4K display compatibility, and options for device and network connectivity and local storage.
Product Description HP t630 - tower - GX-420GI 2 GHz - 4 GB - 8 GB
Type Thin client - tower
Localisation Language: English / region: United Kingdom
Processor 1 x AMD GX-420GI 2 GHz (2.2 GHz) (Quad-Core)
Processor Main Features AMD Turbo CORE Technology
Cache Memory 2 MB L2 Cache
Cache Per Processor 2 MB
RAM 4 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC - PC4-14900
Hard Drive 1 x flash 8 GB - M.2
Optical Storage No optical drive
Graphics Controller AMD Radeon R7E
Networking GigE
Power AC 120/230 V (50/60 Hz)
OS Provided HP Smart Zero Core
Dimensions (WxDxH) 12 cm x 22 cm x 25.1 cm
Weight 1.52 kg
Pricing Type Promo
Environmental Standards ENERGY STAR Qualified
Manufacturer Warranty Limited warranty - parts and labour - 3 years
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP T630 AMD Radeon GX-...
£298.86
